12-14-2013, 08:51 AM   #1
delegopa's Avatar
Nickel Zinc rechargeable batteries (NiZn)
I recently started using Nickel Zinc rechargeable batteries for my Yongnuo flash. So far they seem to hold longer and recharge faster than my normal NiMh. The extra voltage really helps. Using my (old) NiMh or Alcaline in my Camera (K-30) disappointed me a bit, because they depleted way faster than the standard battery.
Considering NiZn is not official supported I wanted to know if anyone so far dared to use it in his camera. Could you share your experience ?
The voltage level of NiZn shouldnt be a problem as the standard Lithium Cells are still higher. Having a higher voltage than NiMh should allow to use more of the actual charge. But I am still not confident enough to put it in my only DSLR...
12-14-2013, 11:16 AM   #2
KevinR's Avatar
I'm not familiar with the NiZn technology, so have to go with what I have read so far. It seems they can be used on electronics which can also take Lithium cells as these both have a similar voltage of about 1.65-1.70v. The energy density capacity of the NiZn seems to be about the same as NiMH, and good NiMH can deliver most of there charge because of very low internal resistance compared to other cells which keeps there effect voltage at an acceptable level (in my case for the K200D, but some devices refuse to work at this voltage).
The caution with these NiZn cells seems to be that they should not be trickle charged as this vents their hydrogen and it seems they don't replenish this so performance degrades more quickly with trick charging over time. Also, you need a special charger for these.
I contrast, I give my NiMH slow charge by default as this yields long life and can be used to boost the batteries safely from any unknown charge state.
One question on your bad experience with NiMH is whether you are using good NiMHs with low self discharge such as Sanyo Eneloops. I had bad results on my K200D with NiMH (Energiser and GP) cells until I changed to using Hybrio, Eneloops and Duracell (white caps = Eneloops).
Would like to hear others experiences with these over the long term.
EDIT: added interesting link for info http://michaelbluejay.com/batteries/rechargeable.html
12-14-2013, 01:25 PM   #3
I use them occasionally on my k-x. The reason it is occasionally is because they don't hold the charge for too long. I use them only when I know I'm going to do some shooting. On those occasions they seem to outlast hybrids.
They do have higher voltage, about 1.7 - 1.8v per cell which means 6.8 - 7.2 v (same as proprietary li-ion batteries).
I don't think they are harmful to the camera but I would be cautious about using them in a flash. They might burn the flash. Because of the fast recycle times you can shoot faster which might lead to overheating.
12-16-2013, 06:02 AM   #4
delegopa's Avatar
Thanks for the feedback.
The NiMh I used weren't low self discharge but usually charged up the evening before. Maybe I will give those a try for comparison. The provided Link was interesting, but the results aren't overwhelming. Now that I have them I will find out how they behave in reality anyway.
Good hint considering flash overheating. I dont know which recent flashes have overheat protection built in and if these systems are intelligent enough to measure the faster recycle time or resulting heat. My Yongnuo is not that expensive but I would still mind its loss. However I will continue using the NiZn with it.
batteries, camera, nimh, nizn, nizn battery, tripod, voltage
rechargeable batteries for Pentax K7 fevbusch Pentax SLR Lens Discussion 6 08-02-2013 07:09 AM
NiZn batteries ok with flashes? JayR Flashes, Lighting, and Studio 14 11-10-2012 09:46 AM
Third Party D-LI109 Rechargeable Batteries Drom Pentax K-r 24 06-12-2012 11:33 AM
NiZn Batteries: A warning m88k Pentax DSLR Discussion 17 08-15-2010 12:51 AM
540FGZ Flash Recycle Times for NiZn Batteries JackBak Flashes, Lighting, and Studio 6 02-04-2010 11:06 AM
All times are GMT -7. The time now is 07:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
