Originally posted by Corto-PA
Yes, I been using this Joby hand strap for a few months on my K-5 and now on my K-3. The strap is very comfortable and secure. I have found it really helps to stabilise the camera when using larger lenses such as the DA* 50-135 and even DA* 300 handheld. I haven't used it with the battery grip but it should adjust sufficiently to fit. The Arca Swiss plate fits securely without interfering with battery cover and makes it very convenient to be able to instantly mount onto tripod without having to remove the strap and attach a separate plate.
I use two different tripods. A compact Sirui ball-head with arca swiss clamp, and a larger Manfrotto with 3-way head and standard quick release plate. Because the Joby grip is now permanently on the K-3, I've just bought an arca Swiss fluid head adapter for the Manfrotto. Also considering buying a second Joby strap for the k-5 as well.
It is quite expensive for what it is, but still Highly recommended (IMO)
