12-20-2013, 07:07 AM   #1
azcavalier's Avatar
Pentax K-3 Power Adapter
I was going to do some time-lapse photography the other day, and realized that I didn't have the power to do what I wanted to do. I know that I could get the extra grip with a second battery, but the K-3 has a port to plug it in to power. Since I was inside, that would have been perfect, and a lot cheaper than the extra grip. Of course, it doesn't come with an adapter, and I can't find one on B&H or Ricoh's site.
Do they actually make a power adapter to plug my camera into the wall?
12-20-2013, 07:48 AM   #2
bluenose's Avatar
Pentax Canada lists AC Adapter Kit K-AC132U Model No. 38780as an accessory for the K-3. B&H has it listed as Pre-order.
Regards
12-20-2013, 09:36 AM   #3
Otis Memorial Pentaxian
QuoteOriginally posted by azcavalier Quote
Finding Pentax accessories is problematic. The Pentax Web Store is worthless and even the best online dealers seldom list all the items that are available. The telephone is our friend. A call to the local dealer or someplace like B&H will usually result in the found part.
12-20-2013, 01:51 PM   #4
I wonder if the K-5/K-5II power adapter will work? That might make it easier to find something to use.
I mean, K-5/K-5II/K-3 all use the same battery, and the plugs on the side of the K-5 and K-3 look the same, and both read 'DC In 8.3V'.
12-23-2013, 09:48 AM   #5
lm4187's Avatar
The K-5 and K-5ii/K-3 cameras supposedly take different adapters.
K-5: K-AC50, and
K-5ii/K-3: K-AC132.
Does anyone know the difference between the AC50 and the AC132? Since I have an AC50 for my K20D and K-5, I would like to avoid spending more money to get an AC132 if possible.
Cheers.
02-15-2014, 06:10 AM   #6
Another quesiton regarding this power adapter: Why $109?!
03-04-2014, 12:44 PM   #7
lm4187's Avatar
Problem seems to be solved.
From our friends and cohorts: AC adapters
BTW, if you do need to buy the K-AC132, the same adapter (D-AC120) can be found in the K-AC128 (for the K-30) or the K-AC1202U (for the K-01) for $10 less. [from the In The Box info at B&H].
Cheers,
Lou
adapter, grip, k-3, pentax k-3 power, plug, power, tripod
What is Pentax power adapter K-AC64's spec? Spec Visitors' Center 5 01-12-2020 08:07 AM
Pentax K-3 + Pentax K-Adapter / M42 va5ja Pentax K-3 & K-3 II 3 11-07-2013 04:13 AM
Good aftermarket batteries for K-5 and AC Power adapter photoleet Pentax K-5 & K-5 II 33 01-07-2013 08:28 PM
Pentax K-AC10U power adapter. Any cheaper options? PentaxKangaroo Pentax Camera and Field Accessories 13 04-05-2008 02:32 AM
All times are GMT -7. The time now is 05:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
