Originally posted by imadethis Hi Dave, the Vivitar 285 will work with NIMH batteries. There seem to be several issues with your flash, but as for NIMH batteries, I can confirm through personal experience that NIMH batteries do work with the 285. If the flash worked with Nicad batteries, they should work with NIMH as they are the same voltage. Could it be that one of the NIMH batteries was low on power or could be a dead battery?
Cheers!
One of the reasons that I tried ni-cads was to see if the 1.2 volts per cell was a factor with this flash. The 2500 mah NIMH cells are all good and used in my camera often. The only thing that I can see is that the nimh cells are fatter and fit very tight. This may be causing distortion of the assembly and loosing contact. They are energizer brand. It just seems strange.
Dave
