12-25-2013, 10:38 AM   #1
Removing Batteries Before Fully Charged
Is it okay to remove the battery from the charger before the green light goes out?
12-25-2013, 12:06 PM   #2
amoringello's Avatar
Of course. :-).
Current battery technology does not suffer from "memory" issues of years ago.
So it is ok to charge near full batteries and to use them if necessary before they are done.
12-25-2013, 12:12 PM   #3
Depends upon which types of batteries you are talking about. Lithium cells should take no harm. NiMH amd NiCd cells suffer from 'memory' and should undergo full discharge-recharge cycles.
12-26-2013, 07:10 AM   #4
Thank you. I was referring to the original battery unit that comes with the K-30.
12-26-2013, 08:09 AM   #5
no harm there,
although it is a good idea every once and a while to do a full discharge and charge cycle. Maybe every 6 months or so drain it all thw way down until the camera shuts off, then charge it fully (or just overnight)
12-26-2013, 09:17 AM   #6
Sounds good, thanks again.
tripod
Pentax k5 problem with fully charged battery? sarahparish91 Pentax K-5 & K-5 II 11 08-17-2013 09:26 AM
Aperture not fully adjustable? stockcharacter Pentax DSLR Discussion 3 05-16-2012 04:14 PM
eneloop (Duracell Pre-Charged) long term report (2+ years) UnknownVT Pentax Camera and Field Accessories 3 12-13-2011 04:53 PM
Optio A36 Fully powers up, then fully powers down. PicturePlant Pentax Compact Cameras 6 08-11-2011 11:45 AM
What's the most customs charged you? LeDave General Talk 20 08-10-2009 10:07 PM
All times are GMT -7. The time now is 11:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
