12-28-2013, 09:10 AM   #16
I sometimes find it more useful to use an ND grad to slightly darken the sky with a very wide lens vs. the polarizer, since it seems to take a lot of work in PP to try to make the sky look normal if you use a polarizer. Or you can just do the ND grad in PP, so long as no area of the sky is bright enough to blow out, but it seems like I often need help from an actual filter for that, especially with the older sensors. I suppose you could always clone sky areas in PP, but I'm not that good at making that look "normal."
cpl, sky, tripod
Is the K5 supposed to focus fast at F5.6? coreyhkh Pentax SLR Lens Discussion 14 07-09-2012 08:53 AM
This guy should be fed to the Crocs an inch at a time... MRRiley General Talk 11 05-05-2011 05:28 PM
K2000, is it supposed to make noise at startup? spystyle Pentax DSLR Discussion 3 01-18-2011 10:21 AM
Is the 55-300 supposed to be this loud? Sitting Bull Pentax SLR Lens Discussion 10 12-10-2010 06:56 AM
Why does this lens produce pictures like this? Skullsroad Troubleshooting and Beginner Help 10 08-21-2010 09:46 PM
All times are GMT -7. The time now is 12:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
