01-06-2014, 10:19 PM   #16
6BQ5's Avatar
It's easy to try a filter and very easy to undo. Just unscrew it. No harm, no foul. So to answer your original question I would say that it is not stupid to buy a cheap filter to experiment with.
01-07-2014, 11:42 AM   #17
QuoteOriginally posted by JimmyDranox Quote
Last time I was in a night club, was a lot of smoke. Cigarette smoke. Someone told me that this smoke is acid. I don't know. Maybe he is right, maybe not. And a lot of vapor, from the vapor machine. A very good environment for a lens.
The front of your lens is the least of your worries in an acid smoke environment. The front element usually has an outer coating that is made specially resistant to as many pollutants as possible as well as being scratch resistant. The same cannot be said for the inner coatings and the other internals of the camera. The real harm happens inside the camera.
However, having said that I very much suspect that the smoke acidity thing is a myth of sorts. I would be more concerned about the very fine dust nature of smoke particles, which might fog optics inside the camera that are unreachable for cleaning and even contaminate lubricants in the camera.
01-07-2014, 11:45 AM   #18
mrNewt's Avatar
You are better off buying a cheap metal lens hood for protection.
I think a filter will affect your image quality... especially in a nightclub...
01-07-2014, 03:46 PM   #19
JimmyDranox's Avatar
A metal hood is a good idea. And a hand strap.
filter, lens, protection, tripod
Is there a GENUINE Neoprene Pentax Neck Strap and where to buy it. Newtophotos Pentax Camera and Field Accessories 8 08-19-2013 07:15 AM
Is it possible to remove the AA filter from a DSLR? TropicalMonkey Pentax DSLR Discussion 7 04-30-2013 12:32 PM
Is it worthwhile to buy a used 645D? slackercruster Pentax Medium Format 6 06-15-2012 01:24 AM
going to buy a used K10D, because ... , is it a good decision ? kamisu Pentax DSLR Discussion 23 03-28-2012 06:55 PM
Is it a good time to buy K-5? nustone Pentax K-5 & K-5 II 7 12-28-2011 05:35 PM
All times are GMT -7. The time now is 08:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
