01-13-2014, 07:08 PM   #1
oxidized's Avatar
Pentax GPS-01 Question
Hi guys,
I just acquired a second hand GPS-01 unit. It came with a small wobble in the base (where it mounts to the hotshoe). Its a very minor one, but it is there (even when tightened to the camera). Is this normal or should I be concerned? Has anyone else experienced this with their GPS unit? Could this simply be something that needs tightening on the inside? Thanks in advance!!
01-13-2014, 07:37 PM   #2
It might just be a bit of wear and tear. Doesn't sound like anything that'll have a practical significance.
01-13-2014, 07:44 PM   #3
oxidized's Avatar
Thanks Adam! One more question. I dont know if you have experience with the unit, but when you try to calibrate you are supposed to rotate the camera around all 3 of it's axes. However, after I rotate it around 2 of them it says "Calibration Complete" and it doesnt let me "fully" complete it.
01-13-2014, 10:07 PM   #4
QuoteOriginally posted by oxidized Quote
I don't think you need to move the camera sequentially along one axis, then the second, then the third. Arbitrary motion is usually what GPS devices ask for.
01-14-2014, 06:12 AM   #5
Pentax/Ricoh has a video on their product homepage demonstrating the calibration procedure:
Calibration | GPS UNIT O-GPS1 | RICOH IMAGING
For simple calibration oxidized is right: Sometimes rotaion around two axis will suffice to achieve calibration. For precise calibration, you'd better expect that you will have to do the sequential three axis rotations several times over.
01-14-2014, 10:37 AM   #6
My O-GPS1 has a similar wobble at the hotshoe connector. As for calibration, the basic calibration is very quick and often completes before I think I've moved the camera enough. Precise calibration (always recommended for astrophotography) requires much more movement.
01-15-2014, 04:38 AM   #7
oxidized's Avatar
QuoteOriginally posted by Stone G. Quote
Thank you!
QuoteOriginally posted by DeadJohn Quote
Thanks! I guess wobble may be just a regular thing with the unit. I still have to fully test it. It has been foggy and rainy last few days
01-15-2014, 02:03 PM   #8
jimr-pdx's Avatar
Is there any speed issue with the rotation, does it calibrate 'better' or timeout with slower camera rotation for example?
The O-GPS1 is on my wish list thanks!
01-15-2014, 03:05 PM   #9
p38arover's Avatar
QuoteOriginally posted by jimr-pdx Quote
I have one but usually forget to take it with me.
01-15-2014, 03:37 PM   #10
Nass's Avatar
No, it's just dependant on it being able to find GPS signal I think. Usually takes me 5-10s at most wobbling it around every way. Then I do the precise one straight after.
01-15-2014, 04:01 PM   #11
You an see the recommeded style of movement in the video at the link I gave above:
01-15-2014, 05:51 PM   #12
jimr-pdx's Avatar
Thanks (again) - that seems like pretty fast movement to me, I just wondered if slower motions had any benefit at all.
tripod, unit
Pentax O-GPS1 GPS - Faulty k-5 or GPS Unit? KansasHorizons.com Pentax Camera and Field Accessories 6 01-04-2014 02:34 PM
Pentax K2000 GPS question? Mcid3 Pentax DSLR Discussion 2 02-16-2013 03:47 PM
Pentax O-GPS1 GPS Unit with K-01 i_trax Pentax K-01 2 12-03-2012 06:49 AM
GPS for K-01 Photodana Pentax K-01 5 04-01-2012 09:19 AM
GPS question and recommendation Newmoon Pentax Medium Format 3 03-28-2012 10:35 AM
All times are GMT -7. The time now is 04:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
