Originally posted by jfdavis58 from ED: "I was concerned that maybe the hotshoe on my camera was faulty but I get exactly the same reading when off camera."
From this I surmise that you powered the flash off the camera, got a beep not a charging whine/zoom motor grind and nothing else?
OK, got mine in my hand: in green mode, wireless to M, side slide to up position, turned power to on. Hearing Charge whine, seeing P=TTL A.zoom, 24mm, 0.0 comp, flash symbol/left triangle black, head tilted.---coming Straight from powered off in bag.
OFF THE CAMERA:
Can you cycle MODE P-TTL to A to M to SB to P-TTL?
In P-TTL can you put the light ON? It times out and goes off automatically.
In P-TTL (light on or off) can you cycle Zoom (A-zoom, M,zoom (24,28...)with the return to 24mm from 85mm a louder distinctive grind?
Try these same variations in other modes.
With the S button:
>>>In P-TTL does compensation function?
>>>In A can you set aperture and shutter speed?
>>>In M can you set power?
With the side switch down can you get to the Format, channel and modeling functions?
There are a couple hidden function that require press and long holds on certain buttons-find these in the manual and try them.
If all this stuff works then you need to do a step by step set-up of mating camera to flash starting with both units in factory default positions and powered off. The flash boots from default, the camera will need a reset through the menus. Use a pencil eraser to lightly rough-up the camera hotshoe contacts--a couple of scrubs.
I'll keep watching for your results; don't give up!
John,
the flash functions all work in each mode EXCEPT the zoom function. It will not zoom no matter what i do. The flash unit also will not come out of manual zoom mode.
When I power up I get a loud beep for about 3 seconds and NO zoom noise at all from the head.
I even measured the pin distance on the shoe and compared against the connections on the camera hot shoe to make sure they would align.
I did try setting the camera to default settings with no flash on it and then turned it off, reinstalled the flash, powered up the camera, waited for camera to be fully ready to shoot and switched on the flash - all the way to the right (not in Wireless mode). In every instance, the result is the same, the beep when powering, and then M zoom and NO zoom function in the head.
Because it acts exactly the same off camera, it leads me to believe that it is another faulty unit. Pentax had no difficulty beliving it was bad, they didn't hesitate, they just said send it back as soon as you can and get another.
I am calling Pentax now.
I'll let you know what I find out.
Ed
