03-10-2014, 07:44 PM   #1
SuperSyx's Avatar
Cheap filter test, expected results or not?
I have tried 2 Polaroid filters and since this my first experience, i am wondering if these results are to be expected or these filters are really junk.
First image is with the Polaroid IR720. I was really suprised the AF was working and the exposition was really fast.
Now the setting sun, filterless.
And with the Polaroid ND 0.9 filter. It gives a weird violet tint.
What do you think, should i upgrade? Stack them? Maybe really easy to correct in Lightroom, I haven't tried yet.
03-10-2014, 09:11 PM   #2
skunktail's Avatar
I can't comment on the IR filter as I've never used one.
The colour cast with the ND is not unusual for a cheap filter (and gets worse the more ND's you stack).
I've switched to Hitech ND filters for this very reason.
03-10-2014, 09:35 PM   #3
I will concur, color casting occurs with most cheap ND filters but is easily fixed in PP.
03-11-2014, 06:10 AM   #4
SuperSyx's Avatar
Good news for the ND filter, I will correct the colours in Lightroom.
For the IR filter, i was shooting at 1/60s. I guess I must buy a darker filter like a 760, 850 or 950... I will just stack the 2 if it not dark enough.
03-11-2014, 06:44 PM   #5
skunktail's Avatar
As I understand it, the IR filter lets through a specific wavelength of light, the number reflects the wavelength - 720nm in your case.
wouldn't stacking different IR filters cause the whole scene to go black (i.e. first filter out everything but 720nm and then filter out everything but 760nm)?
Someone please correct me if I'm wrong.
filter, filters, polaroid, results, tripod
Shots taken my Pentax 645 and advice needed as results are not as expected spotreunion Pentax Medium Format 14 10-15-2013 04:20 PM
Abstract Not what I expected munch008 Photo Critique 8 09-28-2013 07:52 AM
DA 70 f/2.4 Limited test results vodanh1982 Pentax SLR Lens Discussion 30 02-07-2013 07:48 PM
Filter or not? acarpov Troubleshooting and Beginner Help 48 07-26-2009 09:29 AM
UV Filter test - yes, it's what you expected dave9t5 Pentax Camera and Field Accessories 18 05-13-2009 12:46 PM
All times are GMT -7. The time now is 07:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
