03-11-2014, 01:10 PM   #1
sany's Avatar
IR remote for K-r
Hi
Please advice me a cheap IR remote for my Pentax KR. I have seen the accessories section but I am not sure which one will handle burst mode as well, I am looking to get one with burst mode.
Thanks
S
03-11-2014, 01:28 PM   #2
I have the JCC ($6.99) it works well. If your camera is setup right it will even focus before firing and it works from behind the camera in the house, untested out side.
Amazon.com: remote for pentax: Electronics
03-11-2014, 01:30 PM - 1 Like   #3
fgaudet's Avatar
I'm no expert but I cannot get my O-RC1 (pentax waterproof) to fire burst mode with either my Kr or my K5. I may only lack qualification and I did not look in the manual but AFAIK it doesn't work
03-11-2014, 02:04 PM   #4
I'm pretty sure it doesn't work, though I lost my IR remote so I can't test it. The IR mode is a separate drive mode, so you can't select burst mode and IR mode at the same time.
03-11-2014, 02:29 PM   #5
Oops I missed the burst part. No burst available single shot only.
03-11-2014, 06:29 PM   #6
JimJohnson's Avatar
Location: Summer:Lake Superior - Michigan Winter:Texas Hill Country
For the K-r, all IR remotes are going to pretty much have the same capabilities. The range may vary some, but probably not a lot. And by the way, an IR remote advertised for use with Pentax will work with all Pentax cameras that support an IR shutter release.
03-12-2014, 09:53 AM   #7
sany's Avatar
Thanks all for the inputs, I am presuming from geru2000 that burst/bulb mode works with JCC. I will give it a try anyway.
03-12-2014, 10:37 AM   #8
If you have a Samsung Galaxy phone or tablet, (dev says it only works with this model) you can find this on google play: Camera Remote by Andres Sepa. It's free, no ads and works brilliantly with my K-01. Choose Pentax in the settings. Set your camera with whatever remote settings it allows (focus first or not, 2 sec delay or not) then push the button on the app. Like any IR you need to be line of sight holding it more to the front to trigger.
03-15-2014, 05:33 PM   #9
JimJohnson's Avatar
QuoteOriginally posted by lovepics Quote
Samsung Galaxy phone or table with an IR Blaster. Many units in the Galaxy line don't have this feature.
03-15-2014, 06:04 PM   #10
Good point. I've got the S4 and it does. I use my phone as a tv remote, as well. The first sgs I had did not have IR. Thanks for clarifying.
burst, ir, mode, tripod
K-3 Cheap IR remote? alasdair03 Pentax K-3 & K-3 II 23 04-20-2017 11:56 PM
Problem w/K-5 & wireless remote (not IR remote) RockvilleBob Troubleshooting and Beginner Help 2 02-15-2013 01:20 PM
Programmable IR Remote for K-5 v5planet Pentax Camera and Field Accessories 8 12-28-2012 03:57 PM
Enable IR for remote? MrA Pentax K-r 5 07-26-2012 06:56 PM
Is IR filter suitable for K-r? Shingkyo Pentax K-r 16 06-01-2011 11:57 AM
All times are GMT -7. The time now is 08:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
