Hello
So recently I got a used Pentax D-BG4 which works fine for the most part but I noticed on stuck pin in the connector. At first it seemed to make no difference but then I noticed something when I used the pentax battery in there. The charge read-out is wrong and I think the pin has to do with it since everything else works it's probably the one responsible for getting the charge info over.
So when I use the battery in the body it says it's almost fully charged, but when used in the grip, it says it's almost empty.
If I use AA batteries in the grip however it works fine, so I'm guessing the two battery types use different pins for charge read-outs.
So in short, everything works, but the pentax battery read out. I don't know if it negativly impacts the function yet though.
Anyway, has anyone any idea how to get it unstuck without opening it?
I already tried, but holy c**p, this thing has more screws and interlocked parts than an aircraft, so I put it back together before I forgot where everything goes back together.
Here's a pic of the connector:
Thanks in advance!
