03-28-2014, 07:16 PM   #16
Otis Memorial Pentaxian
photolady95's Avatar
QuoteOriginally posted by monoloco Quote
You could attach a small piece of 3/4'" plywood to the fence with a couple of spring clamps or c-clamps then attach the ball head to the plywood. It wouldn't mar the fence at all.
Yes, that is true I could do that, maybe.
QuoteOriginally posted by lmd91343 Quote
The clamp cannot be closed when there is an object (fence board) between the jaws.
The clamp cannot be closed? How would you attach it to something other than a fence post, if it doesn't close? Doesn't that defeat the purpose of it being a clamp?
03-28-2014, 08:13 PM   #17
lmd91343's Avatar
QuoteOriginally posted by photolady95 Quote
Ha ha! The clamp's jaws may be tightly wrapped about an object, but they are still "open" with respect to the "closed" position with nothing in between the jaws.
Look at the geometry. When the clamp's jaws are as close to each other as possible, the flat backs of the clamp, one on each side of the hinge, form a common plane. As the jaws are spread apart, those two flat backs form a "V" with the hinge in the middle. The further the jaws are spread apart, the steeper the "V". That would interfere with the flat bottom of a tripod head.
Imagine a door. It is only closed when it is in its pocket in the wall. Then the door and the wall are flat, in the same plane. Open the door. Put a large book in the door jamb. Try to close the door, you cannot. The door is still open with the book clamped between the door and the wall/jamb. The wall and the door form a shallow "V" with the hinge in the center (vertex). The bigger the book, the steeper the "V". You could not mount a head on the inside of the "V" and have it sit flat on both the door and wall.
I can draw a picture and post it Saturday if you would like.
03-28-2014, 08:23 PM   #18
Thanks I get it. I wouldn't be doing photography if I couldn't "see" what I'm seeing in the viewfinder if I couldn't figure out that simple explanation you gave me above.
03-28-2014, 08:38 PM   #19
lmd91343's Avatar
I don't understand myself most of the time.
Get the device that both Larry and I have. It will do double duty as you can use it in the car also.
03-28-2014, 08:57 PM   #20
The other one Larry posted about looks like it clamps side ways. The camera would be titled that way and I don't want it titled sideways, or vertically. It only shows one photo and no way to tell exactly how it would look clamped to a vertical board.
For the standard Superclamp (which was also part of the kit I linked to), you'd mount a ballhead so it would come out parallel to the ground when the clamp is attached to the top of your fence. When mounted to something vertical like your fence board, you can still aim in all directions with a ball head. In some ways it might not be as convenient as a clamp that lets you mount the ballhead upright on your fence, but it's still very workable. They're also rock solid.
You can see the setup below (to use a ballhead with a superclamp, you need the short stud, not the 'standard stud'...Manfrotto 2909 Super Clamp with 2907 Reversible Short Stud 2909). Cheaper 'knock-offs' are also available. It might not suit your needs though
03-28-2014, 09:07 PM   #21
lmd91343, with me it helps that my late husband was a contractor and we built houses together.
Brian, okay you and Larry have me convinced the one Larry posted is the one I should buy.
Now about that ballhead. I don't have one and don't know what is best without breaking my piggy bank. Any suggestions on that too?
03-28-2014, 10:14 PM   #22
crewl1's Avatar
How much weight are you putting on it?
I bought a cheap ballhead off ebay for my window mount, it works just fine for the limited use and I am attending it while sitting in the car.
I wouldnt put anything too heavy but it holds my DA*300 and camera well.
KS 0 Metal Ball Head Quick Release Plate for Monopod Tripod Stand Camera DV SLR | eBay
If you are putting something heavy on, the weak point may be your fence, not the clamp and ballhead - so take care.
03-28-2014, 10:17 PM   #23
lmd91343's Avatar
Do you have a ball head on your tripod?
03-28-2014, 11:35 PM   #24
Thanks Larry. I can check KEH for a ballhead. I don't do ebay. All I'm putting on this is my K-30 and a Sigma 70-300mm DL Super macro lens. This lens isn't as heavy as my other Sigma 70-300mm macro.
No, lmd91343, I don't have a ballhead. I have a this:
Manfrotto 391RC2 Junior 3-Way Pan/Tilt Head (Black) 391RC2 B&H
03-29-2014, 07:21 AM   #25
lmd91343's Avatar
The head you have will work fine!
03-29-2014, 09:10 AM   #26
crewl1's Avatar
Check this website for some other ideas.
http://www.b-hague.co.uk/vanguard_ph240_window_clamp_with_ball_levelling_head.htm
http://www.amazon.com/gp/aw/d/B0034361JO?pc_redir=1395728680&robot_redir=1
Camera Mounting Brackets and Clamps
After thinking about it some I probably would make something that hooks over the fence out of parts from the hardware store and bolt a ball head to my contraption.
03-29-2014, 03:18 PM   #27
No. I didn't want to use this because it needs replacing. The flat part where the QR is held, tends to not stay flat, it rises up and that makes the camera crooked. And tightening it has no effect. I've had this head for about four years now. And eventually I'll replace it.
Larry, I've put the Vanguard in my wish list at Amazon. I think this would work great and since it comes with a head I don't have to buy a separate ballhead. Which would make buying a pod and ballhead about the same price.
05-11-2014, 08:00 PM   #28
Cullmann travel set
I have a Cullmann travel set that has a clamp, tripod, ground peg, suction cup, and wood screw. They all interconnect. Works great. Mine is from 1982! They recently redesigned a bunch of their parts. I don't know how good the new one is.
M
05-11-2014, 10:37 PM   #29
littledrawe's Avatar
You could use this and add a small ball head to the threaded screw:
Museum of Useful Things - C-Clamp Camera Tripod
05-14-2014, 04:03 PM   #30
Thanks for the other suggestions but I've moved on to other things now and not interested in this option any more.
board, car, fence, tripod
Who uses a 2nd body? jerryleejr Pentax K-5 & K-5 II 53 04-08-2014 03:24 AM
CODE GIVEN AWAY. {I have a KEH code for 7% off, who wants it?} PBandJ Pentax Price Watch 10 09-11-2013 08:22 AM
I am thinking of upgrading my K20D to a K5 of K5II and have a question regarding AF BPT Pentax K-5 & K-5 II 16 01-31-2013 04:39 PM
Who uses a tablet with their photography? opiet70 Photographic Technique 67 04-28-2012 08:34 AM
Who uses a 1 degree spot meter nowadays? germar Photographic Technique 19 12-23-2008 02:16 PM
All times are GMT -7. The time now is 06:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
