03-28-2014, 12:51 PM   #1
Otis Memorial Pentaxian
photolady95's Avatar
I have a question to anyone who uses a car pod
uses a car pod. Like the on in the link below:
http://www.amazon.com/Alpen-Car-Window-Mounting-Device/dp/B000MF4I7O/ref=pd_...AQMR8FTFJFBRYN
What I want to use it for is not my car but our backyard board fence. I hate toting my heavy tripod outside trying to set it up close to the fence hoping it's level and not sinking into the soft sand in our yard. The description gives the demensions but I want to know if the opening that clamps to the window would be wide enough for a board, 1 3/8 inch thick?
03-28-2014, 01:02 PM   #2
monoloco's Avatar
If the opening isn't wide enough, you could always affix a thinner piece of material to the fence to accommodate it.
03-28-2014, 01:18 PM   #3
Looks like it's not even close: Amazon.com: Questions And Answers: What is the maximum width of a window this mount can support?
A superclamp (or knockoff) might do the trick for you, something like Manfrotto Super Clamp with 056 3-D Junior Head 2910 B&H Photo though the clamps themselves are available separately if you have a ballhead that you can attach to the clamp.
03-28-2014, 01:21 PM   #4
crewl1's Avatar
I use a related device by Manfrotto that you attach your own balhead to, it does not open wide enough for your purposes. (Max about 1 CM opening)
Manfrotto 243 Car Window Pod (#3292) 243
You may be better served by a superclamp and put your own ball head on it
Manfrotto 035RL Super Clamp with Standard Stud 035RL B&H Photo
03-28-2014, 03:31 PM   #5
QuoteOriginally posted by monoloco Quote
Thanks but I don't want to mar the fence in any way. To add something to the fence would have me putting nailing something to the boards. Nope.
Thanks Brian but that's out of my price range.
Larry, thank you. Looks good that thing you posted about, if I can find it on Amazon.
03-28-2014, 03:45 PM   #6
lmd91343's Avatar
I have one like Larry's with a Bogen/Manfrotto 308 ball head. The clamp opens to 27/32". Will that be enough?
I would be afraid of using the first one you mentioned. It looks like a disaster waiting to happen.
03-28-2014, 03:59 PM   #7
Gorillapod? That can clamp onto a lot of different things.
03-28-2014, 04:03 PM   #8
The board is only 5/8" inch thick. I just came back inside from measuring it.
This one looks more like what I need:
Manfrotto 386B Nano Clamp - Supports 8.8 lbs (4kg) 386B B&H
The other one Larry posted about looks like it clamps side ways. The camera would be titled that way and I don't want it titled sideways, or vertically. It only shows one photo and no way to tell exactly how it would look clamped to a vertical board.
03-28-2014, 04:07 PM   #9
DeadJohn, There is no way to clamp the Gorrilapod onto the fence board. I don't believe the arms are long enough. The board is 6 inches across and nailed to a slender 1x2 board. Also there isn't enough room for the arms to fit around the board because of the inside board is staggered behind the front board.
03-28-2014, 04:57 PM   #10
Tako Kichi's Avatar
QuoteOriginally posted by photolady95 Quote
Bear in mind that the clamp you linked to above only has female threads and is intended for lighting rigs. You would need to add a male stud (a plain threaded piece) in order to mount a camera or ball head to the clamp. In fact you would be better off with a stud and a knurled 'finger nut' so that you could lock the camera/ball head in the correct position.
EDIT: Looking at the various clamps at B&H it would appear that the 'Nano Clamp' is available with the required stud.
03-28-2014, 05:39 PM   #11
lmd91343's Avatar
I do not believe that the 386B clamp will work for you for two reasons:
1) The area that the clamp is in contact with a flat board is small (only 2 points) leading to instability.
2) More importantly, unless the clamp is almost totally closed, the two flat portions on the top where the stud screws in will not be flat and parallel. That will not allow the bottom of the head to sit flat on the top of the clamp.
03-28-2014, 05:59 PM   #12
QuoteOriginally posted by Tako Kichi Quote
That one I linked to provides an extra stud, male one. And I have another that I could use if needed.
QuoteOriginally posted by lmd91343 Quote
I am not sure what you mean on your second point. It shows the top as flat, would that not be the case with this clamp? I really couldn't find any actual dimensions of the object itself. Is it very small?
03-28-2014, 06:08 PM   #13
Any other suggestions that you all have in mind what I could use? I don't think the clamp Larry linked to would work for me because of what I said in the other post about how it fits the fence. Is there another clamp I could use that doesn't cost almost $100?
03-28-2014, 06:16 PM   #14
monoloco's Avatar
You could attach a small piece of 3/4'" plywood to the fence with a couple of spring clamps or c-clamps then attach the ball head to the plywood. It wouldn't mar the fence at all.
03-28-2014, 06:39 PM   #15
lmd91343's Avatar
The two halves of the clamp (one on either side of the hinge) are only in the same plane (flat and parallel) when the clamp is closed. The clamp cannot be closed when there is an object (fence board) between the jaws. A ball head can only sit securely on a flat surface.
board, car, fence, tripod
Who uses a 2nd body? jerryleejr Pentax K-5 & K-5 II 53 04-08-2014 03:24 AM
CODE GIVEN AWAY. {I have a KEH code for 7% off, who wants it?} PBandJ Pentax Price Watch 10 09-11-2013 08:22 AM
I am thinking of upgrading my K20D to a K5 of K5II and have a question regarding AF BPT Pentax K-5 & K-5 II 16 01-31-2013 04:39 PM
Who uses a tablet with their photography? opiet70 Photographic Technique 67 04-28-2012 08:34 AM
Who uses a 1 degree spot meter nowadays? germar Photographic Technique 19 12-23-2008 02:16 PM
All times are GMT -7. The time now is 06:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
