05-01-2014, 11:34 AM   #1
Safe to carry in one strap mount eyelet
Does anybody know if it's safe to attach a sling strap to one of the strap mount eyelets? Is it strong enough to carry the weight of a camera with a heavier lens (such as 70-300mm)?
05-01-2014, 12:11 PM   #2
GPZ
GPZ's Avatar
Can't tell for the weight but based on my personal experience, make sure to use a display protector.
05-01-2014, 12:20 PM   #3
I would be very surprised if it isn't. I use a handstrap fastened only to one side. The body is metal. Your largest concern may be the quality of the metal your snap clip is made of. Woven nylon rarely fails by fracture and you can keep an eye on it.
Try to avoid bumping into other people.
05-01-2014, 01:10 PM   #4
jatrax's Avatar
I dislike single point of failure systems but strength wise there should not be an issue. Do keep an eye on the strap for any fraying. If it fails you have no backup.
Personally I would not think of doing that. But I'm over protective....
05-01-2014, 01:11 PM   #5
Gerbermiester's Avatar
I've carried my K-5 with a strap and a heavy keychain ring through the strap lug for the last year or so. The only time I had any trouble was when I had a Tamron 70-200mm f/2.8 (a hefty 1.2 Kg) attached to the body; in that instance the problem was actually the swivelling clip on the strap bending, not the strap-lug built into the camera. I've since bent the clip inward a bit to stop the problem from reoccurring. It works perfectly fine with my Sigma 50-150mm f/2.8 (0.77 Kg) attached.
Looking at the clip in the picture, I think you're using the same one as I am. Is yours a 'lensloop' brand strap?
SGH-I757M  Photo
05-01-2014, 02:03 PM   #6
OregonJim's Avatar
For a single-point attachment, I would be more comfortable using the tripod socket. Think BlackRapid R-Strap or similar...
05-01-2014, 02:12 PM - 1 Like   #7
crewl1's Avatar
I have used a single point connection on my K-5's and K-3 with no issues for years.
For large lenses I attach to the tripod mount of the lens rather than the camera so as not to stress the camera lens mount.
I use the Optech USA strap system with a uniloop on the left camera lug only.
(The right lug is used to attach a hand strap.)
OP/TECH USA Uni Loop System Connector
05-01-2014, 02:58 PM   #8
bonaprof's Avatar
I have used the Black Rapid strap for a few years and never had a problem. I do periodically check that it is tight by habit. A double point strap can break too. If either point breaks on a normal strap like the one included with Pentax cameras, the camera weight will pull the strap around your neck and fall to the ground. Any camera strap could fail.
05-01-2014, 10:35 PM   #9
OregonJim's Avatar
QuoteOriginally posted by bonaprof Quote
Very true, but a 'normal' camera strap distributes the weight more or less evenly between two contact points so that each is only bearing half the total weight.
05-02-2014, 07:32 AM   #10
It's what I do as well. I've fashioned my own version of the BlackRapid and I use a couple of carabiners as part of that assembly. I'd ideally like to have a stainless steel flexible tether as "backup" to the other eyelet although that still doesn't prevent the strap itself breaking / being cut.
05-17-2014, 07:26 AM   #11
Thanks for helping out. The Optech sling strap indicates that one eyelet is strong enough to carry the camera.
05-17-2014, 09:49 AM   #12
I carry my K-3 with a Sigma 100-300 f4 with the Op Tech sling adapter with no problems. I have a black rapid where the tripod mount came loose less than a half hr after tightening which caused me to spend $250.00 to repair my camera. I prefer the strap mount of the Op-Tech as the nylon will show wear before failure.
Joe
sling strap, strap, strap mount eyelet, tripod
is Vivitar Series 1 Pentax mount 28mm 1.9 safe to use? penpix Pentax SLR Lens Discussion 5 02-18-2014 12:06 PM
For Sale - Sold: Carry Speed DS-2 Camera Sling STrap nzbk10 Sold Items 2 08-01-2013 08:39 AM
Is K-01 small enough to carry in coat pocket? jeztastic Pentax K-01 9 11-16-2012 09:56 AM
Sling for K-5, is it safe to hold it from only one strap ring ? kamisu Pentax Camera and Field Accessories 17 06-08-2012 11:49 AM
One strap to rule them all... soppy Pentax Camera and Field Accessories 32 12-10-2010 12:00 PM
All times are GMT -7. The time now is 11:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
