I already have a CPL filter but want to start building a filter collection of neutral density filters. My main objective for ND is smoothing water and removing (or at least decreasing) bystanders in architectural images. Secondary use would be a graduated ND for darkening bright skies because CPL doesn't work well at wide angles. I like experimenting and will likely find additional uses for the filters.
The ND filters would be used primarily on my DA* 16-50. 77mm filter size. I can use stepper rings to fit 77mm filters onto smaller lenses. The Cokin P system is theoretically more versatile but is also much bulkier on the camera as well as stored in my camera bag.
Comments appreciated.
