Originally posted by RockvilleBob Thanks for the insight about flash and Better Beamer. I am going out this weekend to shot some birds with the BB and learn how to use the flash fill.
The posted picture above was shot at 1/100 f5 ISO3200
Today I bumped it to 1/250 f6.3 using TAV mode - again taking a shot every 20 minutes. I am hoping the faster shutter and smaller aperture will perk up the shots and I'll just have to deal with the higher noise. Life is full of compromises.
A crow attacked the nest but the robin came back so the egg laying continues.
Fill flash is great for detail as it adds contrast to the minute detail in feathers etc, as well as setting sharp edges to the background
What I do for flash considering you are limited to 1/180 is the following.
I forget that auto modes exist and shoot manual.
I set the shutter to 1/180 and then set the aperture and ISO so that the natural light on the subject, using spot metering, has an exposure of about -1 stop. This ensures mostly natural light for subject and background. Then shoot with the flash and no exposure compensation I check the camera result.
Note you need to consider in this your flash guide number, to make sure you have the power. A better Beamer can improve the GN by 2-3 stops. But you should check this by shooting from about 40-50 feet, at night against a wall, with the aperture and ISO so you are a little beyond the exposure capability of the flash and shoot full power manual. Then add the better Beamer and repeat. In your photo editor, measure the greyscale value in the middle of the frame. Between about 25-30 greyscale and 225-230 greyscale you have about 45 greyscale per stop and the exposure is quite linear. This will tell you how effective it is
