MeFoto is made by Benro. I have their RoadTrip tripod. It can be converted to a monopod simply by removing one of it's legs, the center column, and the ball head. A nice feature but I don't use it that way much. I like the tripod as it's compact, solid, easy to setup, and has a nice case w/shoulder strap. As a monopod it's lightweight, easy to adjust and solid if you don't extend the last section. For a monopod I use a Primos(hunting/rifle) monopod called a "Trigger Stick". I unscrew the "v" rest from the head and put the ballhead(uses Arca Swiss style quick release plates) from my RoadTrip on it. Same threads. Very quick height adjustment. Mades a nice walking/hiking staff IF you don't depend on it to support your body weight.
