06-07-2014, 12:46 PM   #1
LensCoat Lens cover
I was just surfing B&H and came across this lens cover that is "waterproof" but there are cracks in the sleeve to allow the zoom ring to turn. Has anyone used one of these and how effective are they for protecting a non WR lens against rain. I want to get one for my Tamron 70-200 f/2.8. Thanks.
06-07-2014, 03:37 PM   #2
hcc
hcc's Avatar
There are several types of sleeves for zoom lenses. There are very good in rain conditions with a zoom to prevent the raindrop to enter inside the lens when you 'pump in' the zoom. I use personally a home made one. Lenscoat, op/tech are among a few companies making sleeves.
Yes they are useful if you intend to shoot in the rain, even with a WR lens.
06-08-2014, 05:51 PM   #3
The neoprene LensCoat cover protects a lens from bumps, jars and nicks. It also acts as a thermal barrier making your lens more comfortable to handle in hot and cold temps. Depending on the color/pattern it also helps breakup the shape of the lens. The material is waterproof and keeps a good portion of the elements off the lens however as you have mentioned it is not a solid sheet but rather a series of rings allow ing easy access to all the lens functions the areas not covered can still get wet. If you are looking for a cover to use in only inclement conditions than a LensCoat RainCoat should suit your needs RainCoat - LensCoat
06-09-2014, 01:35 PM   #4
littledrawe's Avatar
Also there is this option:
OP/TECH USA Mega Shoot Cover
lens, tripod
LensCoat is looking for Pentax lenses LensCoat Pentax SLR Lens Discussion 17 06-06-2018 02:22 PM
LensCoat® for Pentax DA 560mm ED AW martywk Pentax News and Rumors 7 03-25-2013 05:43 PM
LensCoat for rain protection slackerlee Pentax SLR Lens Discussion 6 03-16-2013 11:04 PM
Hello from LensCoat LensCoat Welcomes and Introductions 5 01-19-2012 05:03 AM
All times are GMT -7. The time now is 05:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
