This is intended to help others avoid a product return I experienced. To make a long story short, do
not buy the B+W MRC circular polarizer due to quality control issues (4 out of 4 filters I tested were optically good but mechanically bad). Try the Hoya HMC Multi-Coated circular polarizer instead. Links provided below.
I needed a 77mm circular polarizer for landscape and architecture photos with my DA* 16-50 lens. I wanted something of good quality but didn't want to spend an exorbitant amount. B+W is a reputable filter company with reasonable prices. The above B+W filter had an overwhelming number of good reviews. A small number of reviewers commented that the B+W polarizer adjustment didn't rotate smoothly but I chalked that up to manufacturing tolerances.
I purchased the B+W filter at B&H. The filter threaded onto my lens well but I had the rotational adjustment problem when adjusting the polarizing effect. Approximately 90 degrees of the rotation was smooth, but the remaining 270 degrees was far too tight, so tight that I couldn't rotate the filter through the filter window in the hood. I had to remove the hood in order to grip the filter tightly enough to adjust it.
The tightness makes the B+W filter very impractical to use. A CPL needs adjustment every time the lens is pointed in a new direction relative to the sun. Each time, I had to remove the hood, adjust the filter, then attach the hood again. Similar steps were needed if I flipped the camera from landscape to portrait. 3 more filters from B&H stock had similar problems.
I then tried a Hoya filter at around the same $110 price point. It turned very easily and smoothly through the full 360 degrees. Photos with the 16-50 look very good with several stops of darkening for blue sky, water reflections, etc. I recommend the Hoya filter.
I provide B&H links here because that's who I used but the above info probably applies to other dealers:
Avoid this
B+W 77mm Circular Polarizer MRC Filter 66-044844 B&H Photo Video
Buy this
Hoya 77mm Circular Polarizer (HMC) Multi-Coated Glass A77CRPL
