Originally posted by neostyles Looking around on the feisol and the vanguard site, i came across these that look pretty nice. I dont know if they are compatible with each other though
Yes, compatible in the sense that the Vanguard head will fit the 3/8" threaded stud on top of the Feisol tripod. No problems there!
Originally posted by Matt Miller I second the Feisol recommendation. Good stuff for sure.
Originally posted by Fl_Gulfer I 3rd Feisol I love mine.
Is it weird to 4th Feisol?
I have a 3401 that I bought in 2003 (was one of the first tripods Orion shipped internationally) and it is
still ready for action today! I had to replace the center column and re-glue the feet back on, but the leg tubes and locks are fine after 11 years of use. The new ones are even better!
Of course, I also own 4 other tripods (Gitzo, Berlebach, Cullmann, Nest) for various uses and occasions, so the Feisol doesn't get out much anymore. And I just finished reviewing 10 travel tripods, so last month
there were 15 tripods in my house (not counting my tabletop tripods, or my lamp made from a tripod)! The Feisol 3441SB was one of the ones in the review, and it is quite nice, but pricey. The big difference between the current 3401 and the 3441 and other Feisols is that the 3401 uses cast aluminum parts instead of machined aluminum. Slight difference in weight and rigidity, but still fine for your D600 and up to a full-frame 70-200mm lens.
BTW, your Ravelli is also sold as Dolica or Weifeng, and that is at the low end of the market (but not quite Polaroid low). Almost anything recommended here will be lighter, stronger, and just better. Particularly with a nice ball head!
