07-01-2014, 07:22 PM   #1
Upgrade 496RC ball head or get a gimbal?
I just a Q10 with a Q to K adapter. Pairing this with my DA* 300mm (effectively 1680mm) I realized how poorly my current ball head (a Manfrotto 496RC2) performed with long lenses - it is virtually impossible locking the ball head on target. Larry and others on the Q thread have switched to gimbals, which is probably the best solution. However, these things are BIG and EXPENSIVE. I found some cheaper solutions, like the Manfrotto 393, which probably would work quite well without spending a fortune.
However, as I researched this I started wondering whether I wouldn't be better off upgrading my 496RC2. As I thought about I usually have problems with locking/framing even with my regular camera and moderate tele lenses. So maybe I should just upgrade the ball head? I realize an expensive ball head might still not work as well as a Gimbal in some scenarios, but the Q+K solution can't really be used for BIF or similar anyway, so I think a ball head really fits my needs better.
I have no idea how much of an improvement I will see if I go to a more expensive solution like a Sirui, a Acratech or a Arca Swiss. Will it be very noticeable? (I would not know where to go and see any of these).
Will these more expensive heads work well on my 055CX? I would prefer to keep the weight to a reasonable amount, which seems to point to the Acratech.. Other Options?
Thanks for you help!
07-01-2014, 07:27 PM   #2
LaurenOE's Avatar
Gimbal!!!!
ProMediaGear Katana!
07-01-2014, 07:31 PM   #3
QuoteOriginally posted by LaurenOE Quote
Gimbal!!!!
One of those BIG and EXPENSIVE solutions it looks awesome, though!
07-01-2014, 08:09 PM   #4
LaurenOE's Avatar
QuoteOriginally posted by HenrikDK Quote
Oh...it is soooooooooooooo awesome.
Katana Gimbal Head Review
07-01-2014, 10:30 PM   #5
crewl1's Avatar
Most decent shops should have a good selection of ball heads to try out.
If you switch to an Arca Swiss style you will be able to use a half gimbal on it if you decide you need a gimbal later.
Like a Promediagear Tomahawk
The ball heads I have now are a Benro B1 that holds the Tomahawk and a similar sized cheap ebay ball that I use on a car window mount.
(I paid like $30 for it. )
07-07-2014, 11:50 PM   #6
If you're not going to go for a bigger lens, then maybe a small side mount type gimbal would work? Something like the Jobu Design BWG Micro Gimbal/Ballhead Adapter. An online retailer like B&H has a pretty decent selection here. Adorama also has a selection here.
496rc ball head, ball, head, lenses, manfrotto, solution, tripod
Upgrade from K-X or just get a 18-135 lens? hray Pentax K-30 & K-50 6 01-10-2014 07:52 AM
Gimbal head. Grrrrrrrrrrrrrrr!!! pntxjack Troubleshooting and Beginner Help 10 11-29-2012 04:00 PM
Manfrotto Junior Geared Head or better ball head? enoxatnep Pentax Camera and Field Accessories 9 05-04-2012 03:33 PM
For Sale - Sold: Manfrotto 190 xproB; Ball head 486rc2 and ball head 808rc4 Not Registered Sold Items 6 05-31-2008 06:06 AM
Pan Head, or Ball head? Mike Bokeh Pentax Camera and Field Accessories 48 05-20-2008 08:04 PM
All times are GMT -7. The time now is 12:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
