Originally posted by chromo Ah I'm starting to get the idea now.
There is an alternative to eyepiece projection, if you can 'live' with more modest magnifications. You can use ordinary teleconverters between T2-ring and camera, a so-called Barlow lens (a tele-negative lens much like a teleconverter) between scope and T2-ring, and even combinations of both:
Here you see the combination from camera and out: 2X Teleconverter + T2-ring with (hidden) 1.25" nosepiece +2.5X apochromatic Barlow. On my 4"/1000mm Newtonian that gives me an effetive focal length of some 5,800 mm. You may read a bit more and see some examples here:
Camera Settings for Astrophotography Be prepared: Even such a relatively modest magnification requires a sturdy mount and a smooth focusing draw tube on your telescope - - - and some patience to get your target framed on the sensor!!!
