07-08-2014, 07:41 AM - 1 Like   #1
SamC's Avatar
AF-540 Flash turns on but no high pitch sound
Hi! I usually like to do some searching first before asking question but I haven't been able to find any useful info yet so want to reach out and see if any other forum members have had similar experiences.
I was traveling in HK recently and brought along the AF-540 to shoot some family gathering. When I set it up the screen turns on and functions as it should and can go to different modes.
But it just won't fire! At first I thought it was not making a good connection with the hotshoe but that realized that the test light doesn't come on or have the high pitch winding sound when the flash is charging.
Anyone know what I can do next and get it back up and running?
Thanks!
Sam
07-08-2014, 09:40 AM   #2
Otis Memorial Pentaxian
Fresh batteries?
07-08-2014, 11:11 AM   #3
SamC's Avatar
Hi Steve,
Yea I thought of that too and put in fresh energizer batteries in today. Still nothing and no sound from the flash.
07-08-2014, 11:52 AM   #4
It's a shot in the dark (yes, pun intended ), but doesn't hurt to try.
Set the charging mode to PP2 according to the procedure on right.
07-09-2014, 05:55 AM   #5
SamC's Avatar
Hi Soldbear!
I followed the steps and the flash is charging now.
I have no idea how this setting got changed (in the check-in luggage) but so glad you were able to suggest this solution. Flash is working great now.
Thanks again!
Sam
07-09-2014, 12:52 PM   #6
Normally the setting of charging mode does not matter if you don't use an external high-voltage power supply (e.g. Quantum Turbo).
There is a mechanical switch at the high-voltage input port. In your case, the switch is stuck, making the flash to think there is a plug in the high-voltage port. Setting the charging mode to PP2 telling the flash there are two power sources: internal and external (external source is 0)
I had a chance to open up the 540 to fix a broken wire, and noticed that the switch was very flimsy.
af-540, af-540 flash, af540 flash, charging, dead, flash, pitch, sound, tripod
New WG-III turns on, but not off, and no image on screen. billykroll Troubleshooting and Beginner Help 4 04-10-2014 03:03 PM
Wireless flash with AF-360 and AF-540 tonyrodgers Flashes, Lighting, and Studio 5 08-13-2012 03:50 AM
Pentax AF 540 FGZ flash problem when on camera netuser Troubleshooting and Beginner Help 24 04-07-2012 04:57 PM
Wanting opinions on Pentax AF-540 FGZ Flash Attachment jimH Flashes, Lighting, and Studio 5 04-02-2009 07:45 PM
All times are GMT -7. The time now is 02:25 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
