Originally posted by MJSfoto1956 I've read elsewhere that many others are in the same predicament -- i.e. access to a bellows but no way to mount a body onto it.
I take it that you are wanting to make an item with a bellows-side flange designed to engage and rotate within the existing fitting on the bellows rear standard. I ask, because that is what it would take to work properly. This is not a situation where gluing a hacked-up M42 adapter would do any good and perhaps by inserting that information into this thread, the inevitable* rat hole can be averted
As you said, there seems to be a recurring request for information regarding these rear mounts. Have you considered simply having a small batch made and attempting to sell on eBay?
* Happens every time due to the well-intention suggestions of people not familiar with how the unit is put together.
---------- Post added 07-18-14 at 01:39 PM ----------
...One more thing...If you do have one made, remember to add a bit of a spacer to allow for clearance of the flash overhang found on modern dSLRs.
