07-30-2014, 01:38 PM   #1
PENTAX O-GPS1 GPS unit
I'm thinking of buying this GPS unit, but it is too expansive for that what it does. So if I could use it for my Arduino devices I would buy it.
I doubt anyone can help me , but anyway does anyone know what the connection type and protocol it uses?
I tried to write an email to lynn.badillo@wildernestlogistics.com, but this email seems to be not workable.
Maybe anyone knows where I have to ask for help?
Oh, almost forget, I have contact with Pentax customer service. I was told there to contact with Lynn (I guess Badillo) 303-728-0359. But I'm not US citizen, and it would be hard for me to speak English. Maybe anyone knows her workable email?
07-30-2014, 01:41 PM   #2
LaurenOE's Avatar
Good luck.
The O-GPS-1 uses Pentax's proprietary digital communication via the hot shoe contacts.
If you're using Arduino, why bother?
There are tons of Arduino GPS devices out there - and they are cheap.
No Arduino GPS? Get a Raspberry PI.
The price for the O-GPS-1 is not bad considering it's WR and pretty well made.
One of my favorite accessories.
07-30-2014, 02:05 PM   #3
I wish I had my O-GPS-1 3 years ago. Sometimes its easy to forget where a picture was taken when you take thousands of pictures in a trip. Now I'm eager to mess with the astrotracer feature. I used it once with decent result for a first try, but I'm still too close to light pollution.
07-30-2014, 02:15 PM   #4
jatrax's Avatar
QuoteOriginally posted by AndreyS Quote
Won't agree with that, one of the best purchases I've made. Saves me an amazing amount of time. I could use an off camera tracker but I find the O-GPS so convenient I have not used my tracker since I got the O-GPS.
But I guess you are trying to use it both on the camera and for another purpose? I agree with LaurenOE, good luck with that. You might be better off getting a more standard GPS tracker or even use one from a cell phone. Much easier to get the information out, and probably cheaper as well.
07-30-2014, 03:20 PM   #5
Since I got a tracking mount, my O-GPS1 has been relegated to providing GPS info to the EXIF. But it excels at that. It can provide orientation data as well which is usually within 5 degrees if calibration has been performed. It is worth every penny to me since a lot of my work is documenting wildlife encounters (bumble bees lately).
Jack
07-30-2014, 03:35 PM   #6
yeah, exactly! I live in the country where $200 per mounth is a good salary. Hence, as for me gps unit is costly.
If anyone knows email of that Lady please share with me
07-30-2014, 03:50 PM   #7
LaurenOE's Avatar
There is no way that anyone at Wildernest logistics is going to know about the O-GPS-1 protocol.
I'm not even sure they still are the parts warehouse for Pentax anymore.
You're at a dead end if you want to reverse engineer the flash/GPS bus protocol.
07-30-2014, 04:30 PM   #8
jatrax's Avatar
Ok, I get that. If I was not selling images it would be too costly for me as well but it saves me money so it is worth it to me. But I don't get why you want to use it? Many other GPS units are available at far less money that would be simple to work with as they use standard and published protocols. So why O-GPS unit? Guess I am missing something.
07-30-2014, 04:58 PM   #9
I enjoy taking with me my k-5, I'd like to buy that O-GPS unit. But if I dont figure out how to use it in my arduino project I'll reject buying it.
07-30-2014, 05:57 PM   #10
OregonJim's Avatar
This sounds backwards to me. In order to use it, you'll have to attempt to reverse engineer the protocol - which means buying a unit before you know if it will work for your project.
07-30-2014, 07:15 PM   #11
Good Evening,
The O-GPS1 unit is not designed to be used as a standalone unit. It is designed to be fully embedded and attached to the designated camera body via the hot shoe interface. The only user controls on the GPS unit is the battery door, on/off button and the two LEDs indicating correct operation. All other user interface activities is through the camera body's rear screen and 4 way control button set (^ v < > and OK).There is no interface specification on the hot shoe and in particular the data pins (neither designation nor data format, although the user's manual calls out NEMA-0183 (using WGS 84). If Pentax had a tethered interface (with a full interface specification that is published, would be a big help) through the USB port of the camera, this would be the interface of choice. However, there is really no interlace information available other than what the somewhat open source software utility PK-tether has been able to discern from their work with the interface. I would drop them an email asking if they (actuary he) has any information that may be of use.I could see a stream of standard NEMA information being produced for time, position (lat, long, alt) and direction being available - however, how you go about extracting it from the camera body, I would guess no one other than Pentax really knows for sure, and they are not talking. The other item is, depending on your application and the latencies involved, I see no way to obtain the PPS (pulse per second), that provides the timing mark for the time, and thus the accuracy.
________________
The O-GPS1 would not be a good choice for a arduino GPS project. There are a lot of options out there with much better interfaces for far less money. The O-GPS1 is a specialized embedded solution intended for use only with the Pentax K camera bodies - and just a few of the recent ones at that. For the camera/GPS solution, it does a pretty good job, especially in the astro tracking mode.
Hope that helps - some,
07-30-2014, 11:48 PM   #12
calsan's Avatar
I just got one two weeks ago - the light pollution is a bigger factor than I anticipated.
To my eyes, the sky looks 'blackish'. The first shot I tried with the astrotracer, I just went for 5 minutes and it was totally overexposed - white with a few even whiter spots where the stars were. I experimented some more and found about 40 seconds was the limit set by light pollution in my neighbourhood. Since then, it's been cloudy nights non-stop. So if you do get one, look forward to cursing at the clouds every night!!
A big factor with the O-GPS1 is that you have star tracking ability in a device that you won't even notice carrying. It's tiny!
07-31-2014, 01:41 AM - 1 Like   #13
QuoteOriginally posted by calsan Quote
I ran across this a while ago....Then, I ran across this....
07-31-2014, 03:07 AM   #14
p38arover's Avatar
I borrowed a friend's aftermarket GPS that fitted into the hotshoe. However, I found it was pretty useless because it used the external flash trigger signal thus, over 1/180th second it didn't record anything.
I bought the O-GPS1.
My biggest concern with it is having it come off the hotshoe and losing it. I should modify it to attach a tether.
07-31-2014, 05:07 AM   #15
Digitalis's Avatar
QuoteOriginally posted by p38arover Quote
Mine attaches pretty firmly, I have never had it fall off in the field on either my K or 645 digital bodies.
contact, email, gps, pentax, pentax o-gps1 gps, tripod, unit
Pentax O-GPS1 GPS - Faulty k-5 or GPS Unit? KansasHorizons.com Pentax Camera and Field Accessories 6 01-04-2014 02:34 PM
For Sale - Sold: Pentax K5IIs, DA 55-300mm, Pentax DA 18-135mm, Pentax DA 35mm, Pentax GPS Unit O-GPS1 mazarelo Sold Items 9 09-27-2013 04:27 PM
Pentax O-GPS1 GPS Unit with K-01 i_trax Pentax K-01 2 12-03-2012 06:49 AM
Pentax O-GPS1 GPS Unit....Questions ??? Confused Pentax DSLR Discussion 11 05-27-2012 08:45 AM
All times are GMT -7. The time now is 04:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
