Originally posted by naturalog I'm considering getting the Tamrac 3536, which I saw was mentioned favorably in another thread, but the $35-plus-shipping price tag is a little high for me right now, especially since I'm making the initial investment for the camera.
I understand perfectly what you are saying. Look into insulated lunch coolers at say Target or KMart. These things...
They come in a variety of sizes, often with a top and a bottom compartment, many have shoulder straps, and they have padding built in in the form of insulation (which also helps in extreme cold and extreme heat); they tend to be pretty weather proof because the lining is designed to hold water in (means it will hold water OUT too!) They tend to look like.. well... lunch, and people don't tend to be looking to steal lunch, and best of all they are inexpensive. If you need to carry a lot of gear and don't have lens cases, think about using a smaller lunch cooler inside a bigger one to hold lenses, etc. A little stick on velcro and you can keep the smaller ones from moving around too much but removable for cleaning. Or get a few of the small bubble-wrap bags (6"x6") and use those for lenses.
Hin has some good ideas here:
Hin's Camera Bags - Hin's Tech Corner
He uses diapers for padding! I understand that. At one point until recently I was up to my waist in these things. Some decent bubble wrap will do as well.
Hope this helps...
woof!
