Originally posted by Driline The large is bigger than both the small and Pro bag correct? So I think it goes Small, Pro, large in terms of size?
Yes large is bigger, will fit a 13 or 15" laptop slid down the back, I hope someone that uses the lenses and Pro bag can chime in. I have the K-5 with 17-50 attached in the centre section, can stack 2-3 small/medium size lenses in one of the other sections and a flash in the third section. I use small bits of high density foam between the lenses and as extra cushion on the bottom just to be safe.
I did previously have a Canon 60D with 60mm lens attached, 70-300 in one section and flash and 40mm in the other, at that stage i tested with a friends Hadley Pro and determined that for the Canon gear it would be too small, and i want to get a laptop in the back when needed, so I purchased the Hadley Large in Black.
