Originally posted by Heie And can you take some pictures of that and how you have that set up? I always have it just hanging free on my sling strap (just like in the image above....yes it held perfectly despite only using one connector - I can't seem to figure out how to use both with the sling strap, so I just leave it connected to only one side...not sure if that's how it's supposed to be done).
Here is how I roll in the field (note the dual Peak Design clips):
Originally posted by Heie Also just out of curiosity....as a Nikon Pro, do you find yourself leaving the D800 kit at home a lot in lieu of the K-3 kit for none other than the obvious reason - Nikon has no equivalent offering, especially for the size.
I'm definitely in love these days with the DA* 60-250mm. If I had only one lens to take anywhere, this would be it. And since it is attached to a Pentax K-3 I would take that too.
---------- Post added 09-20-14 at 05:22 PM ----------
Originally posted by 6BQ5 Where did you find these dividers? Are they generic enough to be used in other bags?
the dividers came with each OpTech USA Accessory Packs. Since I own several, it was no problem "moving them around" to fit the occasion.
