I recently shot a video documentary on an environmental estuarine process: the tidal bore of the Qiantang River in China. This tidal bore can be a 'monster' with the attached photograph showing 3-m high 'wall of water' entering the Qiantang river. Definitely not surfeable: too dangerous at that location for the best tidal bore surfers.
I wanted to record the sound generated by the bore. The tidal bore can be heard between 30 to 60 minutes before it passes an observer, and the rumble sound is somehow similar to the ruble noises of trains and drums. Basically a low frequency noise which can travel over very long distance.
On the rumble noise a tidal bores, a scientific article in a leading international journal:
The rumble sound generated by a tidal bore event in the Baie du Mont Saint Michel - UQ eSpace.
Using my K-3, I tested both the internal mic and an external microphone: the Rode VideoMic Pro shotgun. (Note that I have no vested interest.) The recordings were done mostly at night to reduce the interferences caused by noises of spectators, machinery, cars, ...
To sum up:
-The internal mic of the K-3 was crap. Simply its lowest frequency range was about 100-150 Hz and it could not detect the low rumble frequencies, typically within the range 60-100 Hz.
-The Rode VideoMic Pro shotgun works extremely well. Its frequency range [40 Hz-20,000 Hz] was perfect for the job. The microphone is a shotgun which must be aimed to the source. It is very light (80 g without battery) and ideal for travelling. It was also integrated shock mounting. The con: the buttons are small and almost impossible to use at night. In particular the On/Off button has 3 positions, On, Off and On with 80 Hz cutoff. I got caught up once setting the 80 Hz cutoff by mistake.
Overall I would highly recommend the Rode VideoMic Pro shotgun as an external microphone for the K-3. The small size and light weight are perfect for travelling.
I hope that the experience may assist others.
PS: I posted my review of the Rod VideoMic Pro shotgun at:
https://www.pentaxforums.com/accessoryreviews/rode-videomic-pro-shotgun.html
