11-04-2014, 12:49 PM   #1
Telescope recommendation
Does anyone have any experience or recommendation on beginner astrophotography telescopes that I could use with my k mount cameras? Thanks!
11-04-2014, 01:13 PM   #2
jimr-pdx's Avatar
You will need as much aperture as you can afford, and a stable mount that either tracks the stars or holds things really steady while the O-GPS1 AstroTracer does its thing. This rules out pretty much any sub-$600 telescope unless you feel like making one yourself; I have several home-made 'scopes including a couple where I ground/polished the mirrors myself so it can be done by nearly anyone with time and a little more patience than myself . A six-inch f/5.6 mirror took me forty hours of work and it tests out quite well, and it sits on a plywood mount "Dobsonian style". I can use it as an 850mm f/5.6 but for a couple hundred more it can sit on a tracking platform that provides up to an hour of star-tracking. Here's the link to what I own.
With a K-mount camera balancing that extra weight will be a challenge so I've chosen the Q as my astro-cam; it weighs less than most premium eyepieces!
11-04-2014, 06:10 PM   #3
I'll start with my standard astrophotography advice: look for a local astronomy club. That is likely to shorten your learning curve and prevent you from wasting money on the wrong gear.
What are your astrophotography goals? I ask because if you have fairly high goals, "beginner" gear will be quickly outgrown. Photography through a telescope greatly benefits from a tracking mount such as a german equatorial mount (for refractor or newtonian tubes), a platform like @jimr-pdx linked above (for Dobsonian setups), or an Astrotrac. The mount is more important than the scope.
Different types of photography from easiest to most difficult:
  1. Lunar: Can be done with any fair telephoto lens on a fixed tripod. 300mm or longer recommended. The 55-300 is good, the DA* 300 is better, there are many other acceptable lenses. Many telescopes work, too, if you buy a t-ring mount for your camera. The t-ring goes on in place of a lens and then attaches to the telescope (this is called "prime focus" astrophotography).
  2. Solar: Similar to lunar. You just need to add a solar filter (glass or mylar) to the front of your lens so you don't fry your eye or camera.
  3. Planetary: Jupiter, Saturn, Mars, etc. These planets are small and need lots of magnification. More magnification narrows the field of view and planets quickly move across the field. A tracking mount lets you keep the target centered.
  4. Deep Sky: Very dim objects need a lot of aperture to gather light. The tracking mount lets you take long exposures, repeatedly, then stack them.
astrophotography, recommendation, telescope, tripod
Telescope adapter for 645D FrankC Pentax Medium Format 22 03-11-2020 05:45 PM
Telescope adaptor chromo Pentax Camera and Field Accessories 6 07-03-2014 09:36 AM
Old Pentax Telescope guadua Troubleshooting and Beginner Help 7 04-03-2014 07:13 PM
plastic telescope vs dslr ripit General Talk 6 05-20-2013 10:04 AM
Telescope with K Mount RockvilleBob Pentax SLR Lens Discussion 3 05-20-2013 08:20 AM
All times are GMT -7. The time now is 05:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
