Originally posted by slomojoe I have two, one bought well used, and have had no problems with either one. However, I have simply stopped locking the foot in place, just in case - friction seems to be more than sufficient to hold the flash in the shoe for normal usage. In fact, I have to apply some force and jiggle the flashes to get them off.
Basically, I suspect that unless your flash's foot is very worn, there is little reason to use the pin, and if the foot is worn so much that it has significant give in the shoe, I am not sure the pin would make that much difference to hold it in place (and may cause damage if any momentum is applied to it and the center of the shoe rather than its sides).
Just my 2 cents.
I saw a photo once of a pentax 540 flash on a k10d I believe it was that had fell and when it hit the flash tore the whole top of the camera apart. It was the craziest thing I'd ever seen. So if the shoe is made to break first, it failed miserably in this case!
Since I've read enough reports of pins sticking and the problems it causes I have also chose not to lock down the flash when I use it. It fits very tightly, but I have noticed it move out a bit on the shoe when I have the flash mounted while on a long hike. I don't mount the flash for long hikes often though.
