I have the prior version for the AF400, a handle flash, 102 watt/second; TTL with the LX. Don't confuse the voltage from the TR with shortened recycle time, that is dependent on how fast the flash capacitor recharges, which depends on what percentage of the charge was used in the prior flash, among other factors. My recycle times with the TR are only a few seconds at full power; at lower power settings it is almost instantaneously. BTW, I've heard that the only difference in the two power packs is the design of the connector to the flash unit. Just like Pentax to make an earlier unit incompatible with the latest flash.
