Originally posted by Moropo "what if it unscrews and the camera drops?"
I guess that is possible..... But surely you would notice if it was loose long before it actually came off? Not, IMHO, any more risk than any other strap coming loose.
I prefer the Op/tech sling strap. I have it attached to the tripod plate so I can still use the tripod. The connectors unsnap and snap together without the strap leaving a short loop just big enough for one hand. Since I work off a tripod about half the time this makes it easy. I do not like having the strap on when on the tripod, too easy to snag it and pull everything over. It can create vibrations in the wind as well.
You have to buy the sling strap adapter:
OP/TECH USA Sling Strap Adaptor System Connector and then the actual strap of your choice. The nice thing is you can have multiple straps in different colors to color coordinate
Just un-clip and put a new one on.
