It's a inexpensive Targas monopod from Walmart ($14.99) with a Beike tripod ball-head (eBay $20.10) mounted on top. The monopod came with a 1/4" x 20 stud and the Beike head has a 3/8" insert... so, I took a 3/8" mild steel bolt, drilled and tapped it and made my own adapter. Works like a charm! Much more convenient that the stock monopod.
Although the monopod is an inexpensive one, it is pretty well made, light-weight and I like the way the leg extends, with locking levers vs. the ring that must be turned to lock in place. I keep it attached to my camera and the whole affair is light enough to wear around my neck. To extend it, I just flip the little lever and let gravity do the work! When I'm finished shooting at that particular site, I collapse the leg and I'm off to something else interesting.
This is the second Beike tripod ball head I've purchased. They are extremely well made and quite heavy-duty. They come with a quick-release block, too. My other one has a permanent home on my tripod. I love them.
