01-15-2015, 12:59 PM   #31
GeneV's Avatar
QuoteOriginally posted by Docrwm Quote
Two main reasons. The 8689 is 3x as expensive and has a studio foot not a spike. Also, fewer sections means sturdier in my experience when they're roughly the same total length.
Thanks. I ordered one.
01-15-2015, 02:08 PM   #32
Docrwm's Avatar
QuoteOriginally posted by GeneV Quote
Hope you like it as much as I do.
01-16-2015, 07:00 AM   #33
GeneV's Avatar
The extra foot of length alone will make a big difference.
Just slightly OT, but do others here use SR with a monopod that is long enough not to be awkward? With the 61" Manfrotto, I often felt I still needed it at 300mm.
01-24-2015, 07:43 AM   #34
GeneV's Avatar
I received mine a week ago. It is definitely a different animal from the compact Manfrotto--about twice the folded length and diameter, and a good deal more weight. However, it is far more stable, especially at my height. I may still use the Manfrotto for some light hiking with a compact camera, but the Giottos is definitely superior for any other use. It is stable enough to make shake reduction a minus rather than a plus.
01-24-2015, 09:19 AM   #35
Docrwm's Avatar
I received mine a week ago. It is definitely a different animal from the compact Manfrotto--about twice the folded length and diameter, and a good deal more weight. However, it is fare more stable, especially at my height. I may still use the Manfrotto still for some light hiking with a compact camera, but the Giottos is definitely superior for any other use. It is stable enough to make shake reduction a minus rather than a plus.
My impressions as well. Enjoy!
09-22-2015, 09:58 PM   #36
DavidDwight's Avatar
I'm 6'8" or 203 cm. I just got a Feisol CM-1471
with a Manfrotto 496RC2 ball head and a battery grip on my K5-iis it is barely tall enough in landscape and if I rotate the ball head over for portrait it is short.
I have added a Manfrotto 3229 tilt head on top of the 496RC2 and now when I turn it over into portrait it is just barely tall enough.
so yes, I have 2 heads stacked which has made it heavier than usual but I have tons of adjustability and it is taller.
BTW if you put just the 3229 on the top of the Feisol you can't get the camera over 90 degrees the camera hits the top stage plate of the monopod which is quite large in diameter. It works fine with the ball head solo
monopod, store, tripod
Ok, Lets build a fictional FF K-1s together OldNoob Pentax Full Frame 168 07-22-2014 05:42 AM
Another new person! lapaffe Welcomes and Introductions 5 12-10-2013 08:56 PM
OK Lets Talk Sports seacapt General Talk 22 11-19-2011 01:18 PM
OK...another does this make sense new Pentax person gear list...with diagrams!! :) brecklundin Troubleshooting and Beginner Help 11 06-23-2009 12:46 AM
Lets try this again :P maritimer Post Your Photos! 7 09-25-2008 03:09 AM
All times are GMT -7. The time now is 02:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
