12-15-2014, 11:05 PM   #1
Not sure about the Sirui T-025X
I am looking for a tripod I can hike with and the Sirui T-025x sounds great. Small and lightweight. The review here also sounds very good. But on B&H and other sites I have read reviews that state that this tripod is really not suitable for a DSLR and not stable enough.
Does anybody here have one? Does it work for you? I have a K-3 and will be using the tripod with lenses like DA 12-24 or Samyang 10mm weighing aorund 500g.
---------- Post added 12-15-14 at 10:11 PM ----------
I should add: I don't know any camera stores in the LA area where I can take a look at one. That would be best.
12-15-2014, 11:40 PM   #2
geomez's Avatar
I have one and I use it with my K-3 and my Sigma 10-20mm F3.5 (which is a similar size and weight to your DA 12-24) and the stock ball head. It is very sturdy and I have had no issues. With that set up I have had no slippage nor bending. It has been completely reliable. I have been using it for almost a year hand take it on every hike I go on, which has included Red Rocks near Vegas, nearly all strenuous hikes in the Yosemite Valley, and the Catalina Mountains in Tucson. My only qualm is that it is a little short for me (I'm 6'2"). I highly recommend it.
12-16-2014, 12:45 AM   #3
noelpolar's Avatar
I have used mine for about a year.....very happy with it....it is what it is though.....a tripod optimised for compactness/weight/convienience.
12-16-2014, 04:40 AM - 1 Like   #4
Heie's Avatar
I'm the author of that T-025x review, and I have extensively used it with my cameras (up to K-3) and sometimes even the DA* 60-250.
Have you seen the video that was in that review on the Ballhead page? I strongly encourage you watch it to get an idea of just how strong that unseeming ballhead is
Also, regarding stability, have you seen the laser pointer test in that review? Or the "Real World Usage" page with tons of sample photos, including some detailing long exposures? Recently did a few 30s exposures with the K-3 and DA* 16-50 with no sagging.
Not trying to push it too hard, but I'm very passionate about how since getting it, it's literally the only tripod I use. I have a larger one that I keep 100% in my "studio" now - I never take it with me anywhere.
My only recommendation is get yourself a good Arca Swiss plate, preferably an L-plate (I use a cheap Benro universal plate that I got for $20 on eBay). The tiny plate that comes with the tripod is woefully inadequate and has a tendency to have your camera rotate/sag when in portrait orientation.
Hope this helps.
-Heie
12-16-2014, 05:11 AM   #5
AdrianM's Avatar
Try the 1205X which I believe is a later model. I have had no problems using it with K3, DA*300 f4 and Pentax HD 1.4x RC. Great for hiking.
12-16-2014, 05:48 AM   #6
I recently purchased a T-025X following the positive review by Heie and I'm pretty happy with it - it's SO light and compact!
I attached a K-5 with the DA*60-250 at maximum zoom to it, all legs and the vertical column fully extended, then turned on live view with 10x magnification. When you touch the camera, there is a noticeable wobble which dies off after about 10 seconds, after that it's as sturdy as anything. Even after half an hour there was no sagging.
You should however best use it with the mirror up function to avoid camera shake, and it definitely isn't made for use in strong winds. When using a heavy lens (such as the DA*60-250) and hang your camera bag from the center column to increase stability the legs do however bend quite a bit. But all things considered it is a great tripod for hiking.
12-16-2014, 05:59 AM - 1 Like   #7
bdery's Avatar
Instead of repeating myself, here's what I wrote about that tripod:
https://www.pentaxforums.com/forums/22-pentax-camera-field-accessories/259167...ew-inside.html
Like Heie, I have not used my other tripods once wince I got this one. Not once. It is sturdier than any aluminum tripod I have used and it has let me do 15 minutes night exposures without problems. It's just so good at what it does, I'm constantly amazed.
QuoteOriginally posted by Heie Quote
I find the plate fantastic, in truth. It's so small, with a low profile, I leave it permanently on my camera. Never done that before. It has not twisted or slipped once in about 6 months. I don't feel that I need another plate.
12-16-2014, 06:21 AM   #8
Thanks everybody! I think I will go for it.
12-16-2014, 09:04 AM - 1 Like   #9
edgedemon's Avatar
Second that
I bought it on the strength of Heie's review, never failed me yet, its a great little tripod, you won't be disappointed
12-16-2014, 12:23 PM   #10
QuoteOriginally posted by edgedemon Quote
Second that
The T-005x can be had for $100 less with the same head on Amazon. Does anybody know how they compare? Is carbon fire more sturdy? The weight difference is pretty small.
12-16-2014, 12:59 PM   #11
geomez's Avatar
QuoteOriginally posted by maxxxx Quote
All I know about the T-005X is that it is slightly heavier. Also, cf tripods are generally more vibration resistant. I too would like to see a comparison between the T-005X and the T-025X.
12-24-2014, 06:22 PM   #12
redrockcoulee's Avatar
The T-005 also has a lower capacity if I remember correctly. I bought one for our Cuba trip and thinks it's great. But we only use when flying or with the lighter cameras because otherwise we have a 190 and 055 Manfrotto with us due to LF and MF gear. If it going to be your main tripod I would get the 025, in fact we might get one ourselves some day.
sirui, t-025x, tripod
It's Heie's fault if I got a Sirui T-025X! (personal short review inside) bdery Pentax Camera and Field Accessories 35 01-11-2016 06:24 AM
For Sale - Sold: Sirui T-025x carbon fiber tripod carolina_sky Sold Items 2 09-17-2014 10:07 AM
Why I don't love my Sirui T-025X (although it might be right for you) frogoutofwater Pentax Camera and Field Accessories 3 05-13-2014 06:27 AM
How different between Sirui T-025X and Dolica ZX600B103 tianfeiwei Pentax Camera and Field Accessories 17 03-02-2014 11:00 AM
Sirui T-025x Review - The Perfect Travel Tripod? Heie Pentax Camera and Field Accessories 12 12-18-2013 01:27 PM
All times are GMT -7. The time now is 08:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
