01-04-2015, 10:31 AM   #16
csa
csa's Avatar
Update: I went ahead & just ordered the Ross Photography hinged leveler! I think this will work very well for me, and can be moved to either camera.
Thanks Dentax, for bringing this to our attention!
01-05-2015, 12:14 AM   #17
johnmflores's Avatar
A smartphone app will work in a pinch. Just start it up and place the flat edge or back of the phone on the tripod plate or hot shoe.
01-05-2015, 07:58 AM   #18
csa
csa's Avatar
QuoteOriginally posted by johnmflores Quote
Don't have a smartphone.
01-09-2015, 09:57 AM   #19
csa
csa's Avatar
I received my hot shoe leveler; however it does not fit my K10D. So if anyone is considering ordering one for a K10D, hold off for awhile, as Dennis of Ross Photography is working with me to reach a solution. The edges of the base of the leveler are slightly too thick to slide into the hot shoe.
It is a beautifully crafted leveler, and somehow, someway we will make it fit the K10D!
Stay tuned!
Edit: Dennis is mailing me another that he made thinner, to fit the K10D; I should have it in a couple of days!
I must say, Dennis is certainly going the extra mile for a new customer; I highly recommend dealing with his business!! http://cameralevel.com/ross-photographic.html
01-18-2015, 11:46 AM   #20
csa
csa's Avatar
Received the new hot shoe leveler, and it fits the flash shoe of the K10D perfectly! I must say I'm very pleased with it, and with the exceptional service Dennis provided!
01-18-2015, 12:52 PM   #21
Docrwm's Avatar
QuoteOriginally posted by csa Quote
Always great to hear about good service from a supplier! Don't forget to add the part to the Accessories section of reviews and write up your experiences.
01-18-2015, 02:38 PM   #22
csa
csa's Avatar
QuoteOriginally posted by Docrwm Quote
Thanks, I'll do that!
01-18-2015, 02:55 PM   #23
PEG Moderator
Kerrowdown's Avatar
Is this not something that can be done very readily in PP?
01-21-2015, 08:08 AM   #24
csa
csa's Avatar
QuoteOriginally posted by Kerrowdown Quote
I'm sure it can; however I find this a very handy tool for my panaramas, etc. Many are not too well versed in using PP, to gain full benefits from it; myself included.
I simply was impressed with something made right here in the US with exceptional service! There are many different hot shoe levelers on the market, & this caught my eye that fit my needs. Is it for everyone? Nope, but for those wanting something like this, they can be assured of a top quality product by a guy that cares about his customers. Just thought I'd pass along my experience for others here.
01-21-2015, 11:15 AM   #25
dms
Actually the ability to do in pp is limited--mainly because (in all cases) you lose part of the image--assuming you want a rectangular picture.
In photoshop the rotation and perspective transformations can be done under (both) edits and lens correction. I use the following, but note that if you intend to make a collage/panorama--the problems likely become much harder to seamlessly fix.
-- If it is off in one dimension a simple rotation, or perspective adjustment, but in the latter you (also) lose resolution.
-- If it is off in two dimensions a more complex set of adjustments can be done in principle--but it is harder to see what to do (a simple skew may do it)--and usually looks a bit odd. And again some resolution is lost.
The ability to make a panorama or collage (and the difficulty to fix in pp) is I find often the case because after viewing photo's you may decide to do one.
tripod
Pentax hot shoe adapter + off shoe adapter - any limits on the flashes used? MSL Flashes, Lighting, and Studio 4 10-25-2014 06:13 AM
Hot shoe pins (contacts) voltage? Korg Troubleshooting and Beginner Help 2 07-30-2014 07:06 AM
Hot shoe syncing crossmr Flashes, Lighting, and Studio 12 01-16-2013 04:56 PM
AF360FGZ hot shoe broken godavari Flashes, Lighting, and Studio 4 01-07-2013 09:02 PM
All times are GMT -7. The time now is 01:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
