01-03-2015, 12:23 PM   #1
csa's Avatar
Hot shoe levelers
Anyone have one of these?
Vello Low Profile Bubble Level BL-HS1 B&H Photo Video
If so, how well does it work; or would I be better to go with one of the "cube" levelers.
I want one for usage with my monopod.
Thanks in advance!
01-03-2015, 12:36 PM   #2
Not a Number's Avatar
I've used both and they do the job. The disadvantage with the "bull's eye" type levels is that you need to look straight down at it for most accurate results. If your camera is up high on a support you have to climb up on something to look down at the level. The cube levels you can read from many angles. I suppose you can use a mirror but it will take a lot of practice to get used to the reversed directions.
01-03-2015, 12:58 PM - 1 Like   #3
Ross Camera Level
You might check at cameralevel.com for Ross Camera Level. They are made in USA, money back, if you don't like it for any reason. The camera level is very low profile, because they are folding and locked into place with high strength magnets.
01-03-2015, 01:10 PM   #4
csa
csa's Avatar
QuoteOriginally posted by Dentax Quote
Thank you! A little pricey, however it certainly has great features! I'll give this serious consideration; the hinged one.
01-03-2015, 01:11 PM   #5
csa
csa's Avatar
" The disadvantage with the "bull's eye" type levels is that you need to look straight down at it for most accurate results."
Excellent point!! I never thought of that; this definitely wouldn't work well for me, "in the field".
01-03-2015, 01:12 PM   #6
geomez's Avatar
QuoteOriginally posted by csa Quote
That's why I got one like this for my K-01.
Hot Shoe Two Axis Double Bubble Spirit Level Mount for SLR DSLR Canon | eBay
The part that slides into the hot shoe is too thick, requiring a lot of force to get it on and off.
I do not recommend it.
01-03-2015, 01:17 PM   #7
csa
csa's Avatar
Thanks; I wouldn't want one that was a struggle getting on/off either!
01-03-2015, 02:28 PM   #8
Docrwm's Avatar
Ive got one on my K5iis and its great but I got it from eBay for $3 a couple years ago.
01-03-2015, 02:43 PM   #9
csa
csa's Avatar
Which one are you referring to? The cube?
01-03-2015, 03:31 PM   #10
Docrwm's Avatar
The flat single.
01-03-2015, 03:41 PM   #11
csa
csa's Avatar
Thanks, that was the one I originally was going to get, but since I have my camera at eye level on the tripod/monopod; I wouldn't be able to see the bubble.
01-03-2015, 05:14 PM   #12
dms
I have the two cubes in one w/ two opposing bases (two axis model I believe)--and I find it it requires you look from above (in landscape mode)--but it allows you to level the camera in landscape and potrait mode. I find that most convenient.
01-03-2015, 05:18 PM   #13
csa
csa's Avatar
" I find it it requires you look from above (in landscape mode)"
I still would not find it convenient to look from above, down on the leveler, as I have the camera at eye level on tripod/monopod.
01-03-2015, 05:26 PM   #14
Maybe get a tripod head with bubble levels built-in? Much more expensive of course.
01-03-2015, 06:13 PM   #15
csa
csa's Avatar
Indeed it would be much more expensive; not to mention I already have a very excellent, sturdy tripod, and just bought my new monopod a couple of weeks ago.
$40 for the flip-up leveler seems to be the answer for me.
tripod
Pentax hot shoe adapter + off shoe adapter - any limits on the flashes used? MSL Flashes, Lighting, and Studio 4 10-25-2014 06:13 AM
Hot shoe pins (contacts) voltage? Korg Troubleshooting and Beginner Help 2 07-30-2014 07:06 AM
Hot shoe syncing crossmr Flashes, Lighting, and Studio 12 01-16-2013 04:56 PM
AF360FGZ hot shoe broken godavari Flashes, Lighting, and Studio 4 01-07-2013 09:02 PM
All times are GMT -7. The time now is 01:04 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
