01-21-2015, 01:25 PM   #1
whk1992's Avatar
Hot Shoe Cable Jammed in My K-50
Howdy,
I mounted a cable in reverse direction, and complete jammed it in the hot-shoe mount. Doesn't matter how hard I pull the cable, it won't come out. Any thoughts? Thanks.
01-21-2015, 02:09 PM   #2
ramseybuckeye's Avatar
Get a wide flat head screwdriver and very gently tap from the front of the camera. Try not to have the metal edge of the screw driver touch the cable mount, but have something like a piece of wood between the cable mount and screw driver, that would be much safer. If it slips stop before damaging anything. The piece of wood (or whatever else would be non marring) need to have a flat edge about the size of the edge of the cable mount to avoid damage. Be very careful.
Maybe some duct tape on the screwdriver blade would work as well as wood to avoid scratches.
01-21-2015, 03:50 PM   #3
Edgar_in_Indy's Avatar
I don't understand. How does a cable get stuck in the hot shoe?
01-21-2015, 04:01 PM   #4
UncleVanya's Avatar
Take a big pair of channel lock pliers and crush the plastic head on that cord - if it is metal - ignore me.
01-21-2015, 04:30 PM - 1 Like   #5
whk1992's Avatar
QuoteOriginally posted by ramseybuckeye Quote
That's probably what I'd do if I can't force the mount out by tomorrow. Thanks.
---------- Post added 01-21-15 at 03:31 PM ----------
My friend who's significantly taller and heavier than me won't let me go home easily if I destroy his cable
01-21-2015, 10:07 PM   #6
pacerr's Avatar
See if a very thin feeler gauge leaf will slip between the two parts. You've got something hung on a slightly raised contact in the shoe.
Enough gentle pressure between the parts MAY bend and lift the plastic part just enough to clear the shoe's hang up too.
Look at the shoe on another camera to get a feel for what might be causing the conflict.
01-21-2015, 10:15 PM - 1 Like   #7
Brooke Meyer
Guest
It's probably a spring loaded contact dropped into the hole for the flash locking pin. A very thin feeler gauge may work but you may have to simply sacrifice the hot shoe taking it apart from above.
I stupidly put a Yongnou 603II trigger on a K-5 backwards and the destructively disassembling the $18 trigger was the least expensive option.
01-22-2015, 02:51 AM - 1 Like   #8
whk1992's Avatar
Alright. I admit I'm a person who don't really take care of my gadgets. I don't really care too much about cosmetic issues as far as the functionality is not compromised.
I essentially forced the plastic around the locking pin hole to be deformed by at bit and gave the spring loaded contact (like Brooke Meyer described) some room to retract. Meh, the locking pin hole is larger now, but at least I got the hot shoe out.
Here's a tip: don't ever reverse mount a non-Pentax hot-shot...
cable, driver, edge, metal, mount, piece, screw, screwdriver, shoe cable, tripod, wood
Pentax hot shoe adapter + off shoe adapter - any limits on the flashes used? MSL Flashes, Lighting, and Studio 4 10-25-2014 06:13 AM
Yongnuo flash not firing from Vivitar hot shoe cable ChooseAName Flashes, Lighting, and Studio 3 02-08-2014 08:12 PM
For Sale - Sold: ON HOLD for Pentax Cable F5P et Hot Shoe Adapter F gate1948 Sold Items 0 09-10-2013 10:31 AM
FlashFrame and Hot Shoe Flash Cable fit problem LeroyPK Flashes, Lighting, and Studio 3 12-05-2012 06:55 PM
Is it possible to make a F5P type hot shoe cable myself Darren Pentax Camera and Field Accessories 3 10-05-2008 09:11 PM
All times are GMT -7. The time now is 11:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
