01-29-2015, 11:25 AM   #1
Sagitta's Avatar
Does a K-mount to M42 Adapter exist?
I know that adapters exist allowing M42 lenses to be mounted on K-mount bodies, but I'm wondering if the opposite exists (I assume it would).
The reason is a local shop has an NX Mini on sale for stupidly cheap (It was the display model, its going for under $200), and I'd love to be able to give it the "Q telephoto treatment" if I can mount my old Pentax K-mount lenses on it, but there doesn't seem to be an NXM -> K mount adapter out there, but there IS an NXM -> M42 adapter.
I figure I could just go NXM -> M42 -> K-mount, but a way of making the M42 to K-mount jump is eluding me.
01-29-2015, 11:29 AM   #2
boriscleto's Avatar
No. It would be impossible without optical correction. The K-mount is wider than 42mm.
01-29-2015, 11:50 AM   #3
I think you could go K->NX->NXM, but the adapters will cost more than the camera...
01-29-2015, 12:12 PM   #4
THoog's Avatar
Are you sure there's an M42->NXM adapter? All I can see are M42->NX and NX->NXM adapters.
01-29-2015, 12:18 PM   #5
Sagitta's Avatar
I may have my arrows backwards. I can see adapters where I can stick an M42 on the Mini, but not a K-mount. I'd need some way of kludging a K-mount to the Mini, probably via two adapters of some sort.
01-29-2015, 12:26 PM   #6
Not a Number's Avatar
PreciseParts - Custom Adapters for Astronomy
These guys can fabricate one for you, at around $193 US. It would also act as an extension tube with a minimum of around 20mm.
01-29-2015, 03:16 PM   #7
That could be done by yourself, with glue in RioRico style (a K mount from an old extension plus an adapter "any->NXM").
I don't think glass would be needed, as the register distance of NXM will be certainly much smaller than of the K mount.
So an "extension tube" must be there anyway to adjust for the difference,
adapter, k-mount, k-mount to m42, lenses, m42, m42 adapter, tripod
M42 to K-mount adapter chhayanat Pentax SLR Lens Discussion 20 11-23-2016 12:53 AM
For Sale - Sold: M42 to K mount adapter ClinchShots Sold Items 2 03-16-2014 01:51 PM
For Sale - Sold: Pentax M42 to K Mount Adapter QuixoticTonic Sold Items 2 10-22-2013 12:04 AM
All times are GMT -7. The time now is 09:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
