02-02-2015, 07:43 PM   #1
Adapter Advice
Although I regularly use my k-3, I recently gave in to temptation and purchased a Sony 6000 mirrorless camera (as an experiment and backup), and for Street Photography.
I would like to be able to use my Pentax lenses on the Sony and vice-versa.
Which adapters do you recommend please?
1. There are a confusing number of adapters around for fitting Pentax lenses on an E-mount/NEX Sony camera. I would like to use a pentax 24mm lens on the
Sony as I cannot afford the Zeiss lens ($1400AU), and the Samyang/Rokinon is somewhat cumbersome for street photography.
2. I was not able to find the opposite adapter ... for fitting Sony E-mount/NEX lenses on my k-3 or k-01.
Does one exist?
You may well ask ... why bother, unless you have an expensive Zeiss lens (which I don't and cannot afford)? Well, I purchased two of the Sigma E-mount Art series Primes - the 19mm and the 30mm f/2.8 for $177AU each and thought they might be OK on my Pentax kit.
Thank you
Michael
02-02-2015, 07:51 PM   #2
boriscleto's Avatar
No E mount adapter exits for K mount cameras. The focal flange distance is much shorter on a mirrorless camera so an optical correction element would be needed. This would make the adapter a tele-converter. Another reason is E mount lenses, like all almost all mirrorless lenses, are focus by wire. So it would need to power the lens.
02-02-2015, 08:04 PM   #3
clackers's Avatar
Hi MekiAus,
I have both a Fotodiox and a Novoflex adapter - the latter has an aperture ring for my DA lenses (I often use the DA 70 on a NEX 7), but costs a lot more.
I've got both those Sigma lenses and they're better than the pancake Sony 20mm and 16-50mm I also have.
You won't be able to put them on your Pentax, though.
02-09-2015, 07:08 AM   #4
GeneV's Avatar
I have two Fotodiox adapters, one for PK and one for Zeiss/Contax. The Photodiox has an open/close aperture control, nice for focus wide open. However I also have another, even cheaper, Chinese-made adapter which has no name on it at all purchased on Ebay. It is probably this one Adapter for Pentax PK K Lens to Sony E Mount NEX3 NEX5 NEX7 EX 5N NEX C3 NEX 5c | eBay. This adapter has a knurled ring which allows aperture control with multiple clicks. The clicks aren't labeled, but you can figure it out pretty well and set the aperture to the desired stop.
Both adapters work amazingly well. I mostly use the older lenses with aperture rings so the Photodiox gets the most use. At some point, I may spring for a Novoflex, but right now these seem to do the job.
Edit this is the link for the eBay http://www.ebay.com/itm/Roxsen-Pentax-K-PK-mount-DA-AF-lens-to-Sony-NEX-E-mo...c=1&rmvSB=true
02-09-2015, 07:13 AM   #5
mrNewt's Avatar
QuoteOriginally posted by GeneV Quote
That adapter you are linking to doesn't seems to have aperture control ring.
This is what you would want: Roxsen Pentax K PK Mount Da AF Lens to Sony NEX E Mount Adapter NEX 5 3 5R 7 3N | eBay
Any who, just realized is an old post... probably he found something by now
02-09-2015, 07:26 AM   #6
GeneV's Avatar
I believe you are right, and even the brand looks familiar on this one Roxsen Pentax K PK Mount Da AF Lens to Sony NEX E Mount Adapter NEX 5 3 5R 7 3N | eBay
02-24-2015, 04:39 PM   #7
Hi MekiAus,
Thank you for your advice.
---------- Post added 02-25-15 at 10:44 AM ----------
Thank you all for replying.
I will try one of the low-priced adapters with my existing Pentax lenses.
If the low-priced adapter does not work then i will go for the expensive, but highly rated Novoflex adapter.
Michael
adapter, adapter., camera, da, e-mount, k-3, lens, lenses, nex, novoflex, pentax, photography, sony, street, tripod, zeiss
Seeking Advice RE: PK to NEX Adapter DavidSKAF3 Non-Pentax: Canon, Nikon, Sony, etc. 4 12-05-2014 04:12 PM
k-7 with metz 54 mz-4i and just a hotshoe adapter....advice? zosxavius Flashes, Lighting, and Studio 46 08-17-2013 06:16 AM
M42 adapter advice axl Pentax Camera and Field Accessories 10 05-22-2009 11:28 AM
Adapter advice plse k20d trumpyman Pentax SLR Lens Discussion 3 03-08-2009 09:44 PM
M42 screw-mount adapter advice jsherman999 Pentax SLR Lens Discussion 3 01-29-2008 10:39 AM
All times are GMT -7. The time now is 11:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
