02-14-2015, 12:07 PM   #1
Which filter adapters?
Which make filter adapters (step-up and step-down rings) can you recommend for our lenses?
* I am to buy step-up adapter for my 72mm PL-C filter (Marumi Pro, Ultra slim brass) to be mounted on SMC DA* 50-135mm/2.8 zoom 67mm thread WITH the prioprietary PH-RBK 67mm sun-shade when possible. PH-RBK 67mm internal diameter is enough to acomodate 72mm filter, but its bajonet flange diameter is NOT enough for the shade to be fixed AFTER filter is fixed to the lens, so I expect some tricky play .
* I am also to buy step-up adapter for 77mm PL-C filter to be mounted on the same SMC DA* 50-135mm/2.0 zoom 67mm thread; this might be for travel to have only one-size-fits-all filter (77mm) in a travel bag.
* Just for case I' like also to buy step-down adapter for the above PL-C 72mm filter to be fitted on 77mm filter thread lens (SMC DA* 16-50mm/2.8 and SMC DA 12-24mm/4.0); you never know about vigneting before you live-check, but I do not expect vignetting with SMC DA* 16-50mm at its long end.
There are $3 adapters on the market as well as $33 rings - what is your pesonal experience with them? I'm afraid I am not to spend $$$ for brand-name brass rings
02-14-2015, 01:34 PM   #2
Back in the eighties I decided on using only one size, as I found it too expensive to have PLs, SMC-coated filters and close distance exquipment in 3 different sizes. (For special effects I used a Cokin system). At that time there were no cheap solutions for step-up rings, no Chinese or Eastern Europe offers. Just West German made (expensive), East German made (cheaper and as good) or imported ones (mostly Japanese). Quality of all these was about the same, but many of the cheapest were thicker (whether that's an advantage or disadvantage depends).
Since the time of eBay I bought several sets from China, and they are good enough. You just should have a close look whether the threads were properly cleaned, and occasionally improve this a bit.
02-17-2015, 08:08 PM   #3
MadMathMind's Avatar
I bought mine from Digital Goja on Amazon. They cost like $4 and come with a free microfiber cloth. They don't stick or cause issues for me.
72mm, 77mm, da*, filter, k-mount, pentax lens, rings, slr lens, smc, step-up, thread
Which ND Filter? schnitzer79 Photographic Technique 16 03-11-2015 09:20 PM
Polarizing filter adapters for the Ricoh WG4? edri Pentax Compact Cameras 5 01-02-2015 02:46 AM
Polarizer Filter for which lens? Driline Pentax SLR Lens Discussion 17 08-28-2014 08:30 PM
For Sale - Sold: Adaptall 2 PK/A adapters, Canon FD adapters NRV Shooter Sold Items 5 02-27-2013 01:55 PM
Polarizer Filter and Adapters Help krp Troubleshooting and Beginner Help 10 10-13-2010 05:42 AM
All times are GMT -7. The time now is 05:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
