02-23-2015, 08:00 PM   #1
Pentax Q adapters?
Just got an Q7 Kit and need some advise on third party adapters for it to use the following lens:
  • Pentax 110
  • K-Mount
  • M42
I looked in the reviews and did not see anything there.
Thanks for your input / help.
02-23-2015, 08:37 PM   #2
luftfluss's Avatar
QuoteOriginally posted by Korg Quote
  • Pentax 110
  • K-Mount
  • M42
I asked about the K-Mount adapter, and got wonderful, concise info here:
https://www.pentaxforums.com/forums/136-pentax-q/289087-looking-guidance-adapter.html
02-23-2015, 08:40 PM   #3
boriscleto's Avatar
Plenty of discussion in the Q subforum
Pentax Q - PentaxForums.com
I have a cheap K-mount adapter and am replacing it with the Pentax Adapter Q. No need for an M42 adapter because I can use Pentax Adapter K with it.
02-23-2015, 09:00 PM   #4
  • Pentax 110
  • K-Mount
  • M42
Get the Pentax adapter IMO:
Pentax K to Q-mount Adapter Review - Introduction | PentaxForums.com Reviews
02-23-2015, 09:01 PM   #5
crewl1's Avatar
For 110 there are commercially available 110-Q adapters available.
Check the sticky thread at the top of the Q forum for examples of adapted lenses in the reference thread.
There is advice on how users tweak for best results.
02-23-2015, 10:37 PM   #6
pacerr's Avatar
Macro
QuoteOriginally posted by boriscleto Quote
Plus an M42-to-K adapter which is no problem.
However, a M42 - Q adapter plus some very economical M42 extension rings is a very inexpensive way to explore close-up/macro with M42 lenses. The same could be said for the PK - Q adapter however the extension rings are much bulkier.
E.g., a 20+30mm ring stack will produce a nominal 1:1 macro image with a 50-55mm lens on either the Q or Q7. FOV is on the order of 5-8mm wide from MFD to infinity focus. A single 20mm ring provides a nominal 1:2 ratio and an FOV of appx 10-20mm wide.
[Note: A clamp-type tripod foot around the rings is a good idea to take the weight of the lens off the mount.]
02-24-2015, 11:13 AM   #7
Thanks for everyone's help!
110, adapter, adaptor, k mount adaptor, pentax, pentax q, q7, tripod
For Sale - Sold: Pentax Q, 01 8.5mm F/1.9, Case, Adapters, Caps ElJamoquio Sold Items 7 07-03-2014 09:48 AM
For Sale - Sold: Pentax Q with 01 Prime lens plus K-mount and M42 adapters robwill Sold Items 4 12-08-2013 04:44 PM
For Sale - Sold: Pentax Q body(SOLD), Pentax Q 01 lens(SOLD), Pentax Q Fisheye lens, adapters atcoombs Sold Items 4 11-03-2013 03:06 PM
Anyone consider two Pentax Pk-Q adapters? barondla Pentax Q 6 04-19-2013 03:39 PM
All times are GMT -7. The time now is 12:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
