03-07-2015, 09:29 PM   #1
csa's Avatar
multi card readers
I have an old SanDisk multi card reader that may be going down. Question, is a 3.0 compatible with 2.0 also?
03-07-2015, 09:44 PM   #2
Otis Memorial Pentaxian
photolady95's Avatar
If you buy a multi reader in USB3.0, one that plugs into a USB2.0, then yes, they are backward compatible. Though it will only be USB2.0 speeds.
03-07-2015, 09:49 PM   #3
Yes, USB 3.0 is backwards compatible with USB 2.0. It will work fine, you just won't get 3.0 speed, that's all.
03-07-2015, 10:48 PM   #4
csa
csa's Avatar
Thank you both kindly! Currently my computer only supports 2.0; but I thought since I was going to buy a new card reader it would be nice to get a 3.0 for use with a future computer; but would still work with my present one.
Thanks again, I appreciate it!
03-08-2015, 12:58 AM   #5
Quite often 3.0 reader is faster (due to better electronics inside the reader) even in 2.0 socket.
Old 2.0 readers may not recognize SDXC cards (64GB+).
There is a very affordable Transcend usb 3.0 card reader on Amazon, works flawlessly with my SDXC cards (128GB).
If you have K-3 body, you may want another Transcend reader set (kit) with usb/microusb 3.0 cable, at microusb end compatible with K-3 body microusb socket.
QuoteOriginally posted by csa Quote
03-08-2015, 08:37 AM   #6
csa
csa's Avatar
QuoteOriginally posted by Prakticant Quote
Good information, thanks! I don't have a K3, however. Right now, only 2 K10D's. Seriously thinking of getting a K5IIs.
03-08-2015, 09:49 AM   #7
wtlwdwgn's Avatar
I have a couple of the Transcend 3.0 USB Card Readers. They're the size of a thumb drive. I also have the Lexar Multi Card reader. The little Transcend card reader is much more convenient.
03-08-2015, 02:44 PM   #8
csa
csa's Avatar
The size really isn't important, as I have it on my desk, connected to the computer.
03-14-2015, 08:41 AM   #9
I have a bunch of these things in a junk box. They work a couple of times then don't. All the brands.
I will spend money for a reliable card reader, USB 3. What should I buy?
03-15-2015, 04:36 PM   #10
panoguy's Avatar
QuoteOriginally posted by wtlwdwgn Quote
QuoteOriginally posted by derekkite Quote
The Lexar was recommended to me by a local photojournalist. He said pretty much everyone he knows uses one to get their CF cards onto laptops, tablets, and desktops in the office. Apparently, they don't end up in the junk bin. So far, mine hasn't quit after 18 months of occasional, dusty use (it's for my Sigma SD1 CF cards - my iMac has a built-in SD slot).
03-15-2015, 04:42 PM   #11
PCI-E slot? If so, you can get a PCI-E card that will give you USB 3.0.
An example:
SYBA Model SD-PEX20139 PCI Express to USB Card Add-On Card - Newegg.com
The one I linked to has the 19-pin header so you can add USB 3.0 ports to the front of your PC if your case allows for it.
03-15-2015, 06:38 PM   #12
csa
csa's Avatar
QuoteOriginally posted by r0ckstarr Quote
An example:
Sorry, I don't know what slot my computer has. I know very little about computers; self taught, and my teacher was a dummy in this field.
03-16-2015, 05:26 AM   #13
bdery's Avatar
Yes.
check this one out, I'm using it currently and it's a fine one:
Amazon.com: Anker® USB 3.0 Card Reader 8-in-1 for SDXC, SDHC, SD, MMC, RS-MMC, Micro SDXC, Micro SD, Micro SDHC Card, Support UHS-I Cards, 18 Months Warranty: Computers & Accessories
03-16-2015, 12:54 PM   #14
emalvick's Avatar
I've spent money on card-readers... they still go out, especially the type that you mount into a disk-bay. My best success has actually been from little thumb-drive form drives that work with just one or two card types. My recent selection are the Transcend ones mentioned earlier. They are the fastest readers I've had, even compared to my previous USB 3 reader, and they are cheap. I bought a few of them. I keep one always with my camera bag, one always in my home desk (for my computer), and a last one floats around a bit (mostly at work or with my laptop).
I sometimes think the multi-card (1 size fits all) readers are biting off more than they can chew by trying to work with every card type in the world. I replaced my last built in card-reader with a USB 3 header instead. It provides a lot more benefit than I expected in addition to the transcend card readers I have.
card, multi, tripod
Are all card readers crap? dadipentak Pentax Camera and Field Accessories 25 11-16-2011 10:13 PM
PENTAX K-7 Voted Readers’ Choice Camera 2009 by Adorama Learning Center Readers Adam Homepage & Official Pentax News 3 01-04-2010 04:14 PM
memory card readers; which one? rdrum76 Pentax Camera and Field Accessories 9 02-02-2009 10:25 PM
Card readers trishytee General Talk 2 01-08-2009 08:12 PM
are there any fast card readers that support SDHC? shadowrulz3164 General Talk 11 03-01-2007 09:50 PM
All times are GMT -7. The time now is 05:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
