I'm looking for ideas for using my Black Rapid strap along with my tripod plate, as to not have to unscrew anything when changing back and forth.
My tripod is a Ravelli APGL5 (
Ravelli 65 Inch Ball Head Camera Photo Tripod APGL5 - Review)
I'm already aware of ArcaSwiss plates and Manfrotto plates that have adapters for screwing in additional tripod accessories... This is no an option for me as the tripod I have is incompatible with these systems, unfortunately.
I'm curious if another option (cheaper) may be available; other than changing tripod plate systems.
I really love my tripod, the fluid ball head is great and the mounting system is very sturdy and well constructed metal. Changing systems now if out of the question. So here are my options (feel free to add alternatives you have heard of or tried yourself!):
Luma Labs — Membrane Connection from Luma Labs - Luma Labs Membrane Connector: Allowing me to fasten between the plate and my camera.
http://www.amazon.com/gp/product/B0062TOA4U/ref=ox_sc_act_title_1?ie=UTF8&ps...A22PRX6WI8E2K6 - Generic plate with 1/4'' 20 threads to place on the base of my camera first, then attach the plate and the BR clip... This option may hinder access to battery compartment; still need to measure.
http://joby.com/camera-straps/ultraplate-quick-release-plate - Joby Ultraplate: I won't be able to use the system, so I'd have to simply use it similar to the generic plate above (costs more and is thicker/shorter; least desirable option...)
Let me know if anyone has had success with a DIY alternative!
I've contemplated using paracord (550lb test) and dremel a hole into the tripod plate. This may reduce the strength of the plate though, and I'd still have to remove the sling to attach to tripod each time.
