I was quoting
Marumi Digital PRO brass series which I got (
1 polarizer, 3 protectors), not
Marumi DHG Super which is different series I do not own.
Polarizer is not just coating, polarizer is the stuff sandwitched between the two pieces of glass.
The quoted cast of
Marumi PRO and
Hoya HD concerns the reflected picture (
loook at your filter at angle, from the 'outside' and from the 'inside' esp. for Circular-PL), not the light which passes through the filter.
B+W (
at least top series) are sealed around the glass, profitable in humid/wet environments (
against fungus build-up, etc.).
You may study someone's work here:
www.lenstip.com/115.1-article-Polarizing_filters_test_Introduction.html
Originally posted by Nicolas06 Marumi DHG super are apparently good too.
