Show Printable Version 7 Likes Search this Thread
04-24-2015, 04:40 PM   #16
Aaron28's Avatar
98.24% awesome! hahaha!
04-24-2015, 05:19 PM   #17
I've been using BR $20 knockoffs for several years with no trouble. I once had the chance to compare it directly with an actual BR strap, and was hard pressed to spot any difference.
04-24-2015, 06:19 PM   #18
Banned
QuoteOriginally posted by K(s)evin Quote
The screw that attaches the plate to the grip is in a 1 1/4" slot, which allows you to slide the plate and line it up under the lens, rather than where Pentax chose to put it
I believe the tripod mount hole is off center on the grip so you can still attach / use the Pentax hand strap.
04-24-2015, 07:17 PM   #19
dadipentak's Avatar
I use a BR ("Cross-Shot" I guess) fairly often when I'm on a two-body outing--works for me.
04-25-2015, 12:12 AM   #20
K(s)evin's Avatar
QuoteOriginally posted by Al_Kahollick Quote
Yup, that is what I was trying to say. It has always annoyed me that Pentax put the tripod mount hole on the battery grip off to one side, instead of it being centered under the lens mount. The Joby Ultraplate slides so that you can iock it down where YOU want it. Put the extra mount hole under the lens, or slide it over to make it easier to attach a wrist/hand strap!
04-25-2015, 02:40 AM   #21
QuoteOriginally posted by dadipentak Quote
One body on the BR, the other on the neck strap?
04-25-2015, 03:22 AM   #22
p38arover's Avatar
QuoteOriginally posted by noelpolar Quote
I use the Black Rapid curve when needed....heaps better then a neck strap.
And then you can get the sewing machine out and cut up the old pentax neck strap and make it into a wrist strap.....I use just a wrist strap 98.24% of the time.
I have a Black Rapid that I occasionally use - mainly for carrying the second camera. The main camera is on a wrist strap that I bought 40+ years ago.
I'm always worried by the Black Rapid. I've had it come undone a couple of times and had the camera drop to the ground - fortunately onto carpet.
04-25-2015, 06:09 AM - 1 Like   #23
dadipentak's Avatar
QuoteOriginally posted by r0ckstarr Quote
No, I never use a neck strap. The other body is either on a monopod long lens or in a holster bag.
04-25-2015, 06:23 AM   #24
noelpolar's Avatar
QuoteOriginally posted by p38arover Quote
I haven't had that happen yet...tend to keep an eye on it...fingers crossed.....but I do only use it 1.76% of the time...
I tend to only use it with heavier lenses like a 70-200 2.8..... or on a long walk with a 300 on.....then I also tend to have the wrist strap on and just let the strap take the weight to rest my arm.
04-25-2015, 06:32 AM   #25
Banned
I've read other stories of this happening, which is why I got the tether system. Never had anything loosen up in the 2+ yrs. I've been using BR, so the tether is just an added bit of reassurance.
04-25-2015, 06:47 AM   #26
dadipentak's Avatar
Me too--which puzzles me. I don't really worry about it. I do habitually tighten the fastener--but I've never found that it's loosened.
04-25-2015, 07:02 AM   #27
crewl1's Avatar
Here's the thing that swayed my choice to use the Optech system:
The only part of the camera that was designed from the start to be used to suspend it, is the strap lug.
I know no one has ever reported a bottom plate coming apart or the stress of hanging from the tripod mount tweaking any internal pc boards or electronics but it still gives me the heebie jeebies.
It's my hang up, I know. (Pun intended.)
04-25-2015, 09:19 AM   #28
QuoteOriginally posted by crewl1 Quote
05-04-2015, 01:37 AM   #29
I have been meaning to buy a dual harness from BR to be used for events, but I am a bit hesitant because I don't want to look a like going to a combat.:P
05-04-2015, 03:49 AM   #30
Banned
QuoteOriginally posted by wed7 Quote
Check out the Yeti, doesn't look like combat gear, and is quite comfortable......
BlackRapid Yeti Strap
black rapid, camera, jacket, rubber, shoulder, sling, strap, straps, tripod, washer, yeti
Black Rapid clone Dual Shoulder Sling - $20 rawr Pentax Camera and Field Accessories 2 11-19-2013 02:12 PM
Red River Papers anyone use them. telfish Digital Processing, Software, and Printing 3 10-14-2010 06:55 PM
Anyone here that use to work for Ritz Camera got some Claims Forms from them?? iNVision ART General Talk 4 08-18-2009 07:14 PM
Color polarisers - anyone use them? Sergei Pentax DSLR Discussion 4 05-17-2008 05:49 PM
All times are GMT -7. The time now is 08:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
