04-28-2015, 04:06 AM   #1
philodragon's Avatar
Lens Hoods
I'm new to buying lens hoods, as well as being new as a Pentax owner, and would like to know if all lens hoods will work on a lens as long as they state the same size as the lens (i.e. - 49mm). Are lens hoods standard across the manufacturers or do they differ in some way even if they are say 49mm?
I'm looking to buy some hoods on eBay but some do not specifically say Pentax on them. I'm wondering if they will still work for my lenses, provided that I buy the one that corresponds to my lens.
Last edited by philodragon; 04-28-2015 at 04:06 AM. Reason: lens hoods, hood, pentax
04-28-2015, 04:15 AM   #2
Oldbayrunner's Avatar
If they are the screw in type, then usually no. If they are the mfg bayonet knock offs then yes they can vary and not fit guite correctly.
PS the pentax hoods can vary between lens models of the same focal length. Example; an 18-55mm wr plastic mount bayonet uses a slightly different hood than the 18-55 mm wr metal mount bayonet even though both are 52mm.
04-28-2015, 04:31 AM   #3
sapporodan's Avatar
I think different manufactures use different bayonet mounts on the front of their lenses, I am pretty sure a hood from a 52mm Nikon lens will not fit on a 52mm Canon lens etc.
Also hoods are usually designed to work on specific lenses and can cause problems if you use them on other lenses i.e. if the hood it too deep it will cause vignetting or if the hoods too shallow it wont shade the lens so it will be pointless.
Saying that you can buy universal hoods but usually they don't works as well.
If I remember correctly TheCameraStoreTV did a rather good explanation about hoods on Youtube.
04-28-2015, 04:37 AM   #4
I very much doubt that the =49 means that the hood will work on all lenses. That figure refers to the diameter of the filter ring on the front of the lens, and has nothing to do with the focal length of the lens. For example, the 49 mm hood on my 100WR macro lens is very long/deep, and would cause vignetting on my 50 mm, and EXTREME tunnel vision on a wide-angle lens like the DA21. However, a cheap collection of miscellaneous hoods could be very useful - I struggled for ages to find a cheap hood for my ancient 50, and it looks far too short to be totally effective.
---------- Post added 04-28-15 at 07:39 PM ----------
Bah, sapporodan beat me too it, I should type faster!
04-28-2015, 04:46 AM   #5
Lowell Goudge's Avatar
QuoteOriginally posted by philodragon Quote
There are a lot of factors for a lens hood, but the three critical are as follows:
-filter diameter. Obviously, of it can't screw onto the front off the lens it won't work (same for bayonet type hoods,mr hey must be compatible with your lens)
- hood depth. Deep hoods offer more protection for flare and also boost contrast by reducing the light outside the lens field of view from entering the lens, this light must be absorbed internally in baffles and can lead to reduced contrast as well.
-hood diameter is also important, a hood that is significantly larger diameter needs to be proportionally longer on any lens to offer the same protection
For me, I like hoods that are just large enough to be turned over and fit over the lens barrel for storage in my bag.
There is a file, which I uploaded some time back called hoodcalc. It is a spreadsheet that can calculate the optimum hood length for any known diameter loos, and for any lens focal length/sensor combination
04-28-2015, 06:02 AM   #6
Well, right now I am shopping for hoods for my Rikenon 50mm F2 and my 35mm 2.4 Plastic Fantastic. I was thinking of getting some of the universal rubber hoods that allow for multi-function and wondered if they would fit; seeing as some of them are not listed as specifically working with Pentax or Rikenon.
The question is, on my lenses, do I go by the " 49mm" inscription when shopping for hoods or something else?
04-28-2015, 06:05 AM   #7
Spodeworld's Avatar
I tend to go with the metal screw in types, since they protect the lens better. Look for one that is not too deep, and it should work OK. If it says telephoto or wide angle, then maybe you should skip those.
04-28-2015, 06:26 AM   #8
TER-OR's Avatar
A bunch of the rubber ones have three extension options. With the 50mm a middle deployment is usually good.
04-28-2015, 06:27 AM   #9
Hoods meant for film camera lenses are too short for crop sensor bodies. I have a dedicated hood for most of my older lenses and DA lenses. My best FAs are stuck with their original petal hoods and they are shorter than I would like. When the FF comes out I expect new lenses to come with two hoods.
04-28-2015, 06:33 AM   #10
stillshot2's Avatar
If you bump into a wall with a screw on collapsible rubber hood, the rubber will give. If it is a metal or hard plastic screw in hood, you could break off the hood, taking the threads with it. I'd go with a cheap collapsible rubber one that is easier to store and will work with more lenses.
04-28-2015, 06:43 AM   #11
I'm leaning toward the adjustable rubber hoods at this point.
04-28-2015, 06:45 AM   #12
Closed Account
If you know the official "pentax"-name for the lenshood, like PH-RBI 58mm for the HD 55-300mm WR it is easy to find them on eBay. I believe JJC sell a lot of these for far better prices and in the same quality
just try this one: http://www.ebay.de/itm/Parasol-PH-RBG-58mm-PENTAX-compatible-/331188169646?p...item4d1c5a6bae
04-28-2015, 06:54 AM   #13
QuoteOriginally posted by BertH Quote
just try this one: Parasol PH-RBG 58mm PENTAX compatible | eBay
That link is in German (the Germany eBay). I'm in California. I'm going to stick with USA for now actually. My naked lenses right now are the Rikenon 50mm F2 and the Plastic Fantastic Pentax 35mm 2.4.
04-28-2015, 07:01 AM - 1 Like   #14
Fat Albert's Avatar
New Metal Standard 49mm Screw in Lens Hood Cap | eBay
I use this one on my fifties and my 35/2.4 when I owned one.
04-28-2015, 07:03 AM   #15
Closed Account
try the american eBay and make a quick search for b.e. PH-RBI 58mm. Probably the same eBay-shop!
I always the german ebay, its the best on mainland Europe
49mm, hood, hoods, lens, mm, pentax, tripod
Ebay lens hoods pentasonic49 Pentax SLR Lens Discussion 6 09-04-2013 09:23 AM
lens hoods diy slip Pentax SLR Lens Discussion 2 02-15-2013 05:18 AM
Worn Bayonet Lens Hoods WPRESTO Pentax SLR Lens Discussion 9 04-07-2012 06:59 AM
About Lens Hoods RETAKE! MightyMike Photographic Technique 10 01-20-2009 11:38 PM
All times are GMT -7. The time now is 10:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
