05-14-2015, 01:05 PM   #1
BigMackCam's Avatar
D-BG5 battery grip - how strong is the tripod mount?
I was looking inside the battery compartment of my D-BG5 this evening (actually, to see where the extra SD card is stored!), and I noticed that the whole construction of the D-BG5 looks less robust than the K3 I use it with. Specifically, the body of the battery grip is some sort of poly-carbonate type material, and the tripod mount appears to be held in place by a thin metal plate inside the base (if you look inside, my description will make more sense!).
Now, I happen to use a BlackRapid RS-7 strap, with a fastening stud that screws into the tripod mount. It got me wondering just how strong that mount is. I wouldn't give it a second thought if I was attaching the stud to the mount on the camera body, as that's held in place within the alloy enclosure. But, as I say, the D-BG5 feels flimsier to me.
Concerns around the BlackRapid strap-to-camera attachment design aside, do you think the tripod mount in the D-BG5 can safely handle the weight of the camera, lens and grip for regular use?
05-14-2015, 01:45 PM   #2
I've never had any problems with mine using a BlackRapid strap - it seems solid enough to me.
05-14-2015, 01:49 PM   #3
Yes it certainly can. The weight is distributed among the tripod mount and several pins located around the edges of the grip, plus there's the friction between the two surfaces.
05-14-2015, 01:57 PM   #4
blackcloudbrew's Avatar
Yep, I'm a BR strap user and have never had a problem with the BG-2, -4, or -5 grips. I think if I mounted my silver K3+silver BG5 grip on a tripod (sturdy one mind you), and took a baseball bat to the camera, I believe I could serious damage both the camera and the grip before the mount broke off the tripod...
I will say (more seriously this time) that longer lenses, such as the Sigma 150-500 lens, have a tripod foot to balance the weight of the lens and camera so all that torque on the camera mount is relieved. That said, I *think* I've actually used my BR strap attached to my K5+BG4 grip and Manfrotto plate a bit and never worried either.
05-14-2015, 02:25 PM   #5
BigMackCam's Avatar
Thanks, all - very good to hear. I figured Pentax wouldn't allow this to be a weak spot in the D-BG5, but had to ask!
Ah, that makes sense. OK, I'll stop fretting now! Thanks, Adam...
05-14-2015, 06:04 PM   #6
imtheguy's Avatar
Adding an option here but I may be the only one that uses it.
As a long time BR and grip user, I too was concerned when attaching any lens large enough to have its own tripod foot. So for the da*300 glass and up, I added a second sliding connector to the BR strap and connect to the lens foot also. The dual connection does not impair using the camera but leaves me feeling more confident as I bounce around the landscape.
05-14-2015, 07:18 PM   #7
Banned
I use their tether system, with a couple of extra carabiners as quick release clips, for added piece of mind.
See here: https://www.pentaxforums.com/forums/22-pentax-camera-field-accessories/293336...ml#post3225200
battery, blackrapid, body, camera, d-bg5, d-bg5 battery grip, grip, k3, mount, rs-7, strap, stud, tripod, tripod mount
How strong is the Q10 mount ? PenPusher Pentax Q 3 01-01-2015 11:47 AM
For Sale - Sold: Pentax D-BG5 Battery Grip petez Sold Items 5 06-15-2014 05:51 PM
For Sale - Sold: Pentax D-BG5 battery grip (K-3) karro Sold Items 3 05-29-2014 11:40 AM
Wanted - Acquired: Battery grip D-BG5 for K-3 nicoprod Sold Items 2 03-14-2014 08:59 AM
Is the D-BG2 Battery Grip tripod-mountable? aweir Pentax Camera and Field Accessories 4 03-30-2009 09:55 AM
All times are GMT -7. The time now is 06:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
